20 Most Recent Sirius Satellite Radio Receiver Questions & Answers
Sirius is not free. You paying for the service and not getting results? If latter is case you contact them for support.
Sirius Satellite... | Answered on Sep 12, 2017
hi there, you can try to change the radio, if not, you have to see the outside cable signal catcher.
Sirius Satellite... | Answered on May 05, 2017
An ohm meter across the contacts of the switch, with the battery removed, will show you if it has shorted. If you get a full scale defection on the meter, just like touching the test probes together, in the off position you will have a short.
Sirius Satellite... | Answered on Apr 08, 2017
Try resetting it to defaults if you haven't done that yet. I had a similar problem with a Stratus 4, and that took care of it for me.. Sounds like perhaps some kind of NVRAM gets corrupted and a full reset clears it up.
Good Luck. Hope it helps you like it did me.. Just remember to jot down all your presets first, because you will need to reset them.
Sirius Satellite... | Answered on Mar 18, 2015
Can you be more specific about what model number you are using? Is this a car in-dash unit or a boombox, or what? Thanks.
Sirius Satellite... | Answered on Oct 30, 2014
First question is if you ever spilled a soft drink into the radio such that the AM/FM/SAT switch gets sticky?
2nd, do you have any way to pull-out the radio and borrow a magnetic-mount Sirius antenna to temporarily test and see if the antenna on the vehicle is bad?
If passing the first two tests, then it's likely the whole radio unit has to be replaced with a model from a similar year. Actually, the audio quality you get from an XM Onyx will be much better than the Sirius radio in the Chrysler vehicles, and you can just use the AUX input on the radio for playback.
Sirius Satellite... | Answered on Sep 11, 2014
Most GM radios are coded to only work in the car with a matching VIN number, so most of the time you cannot do it, sorry to say. Actually, the new ONYX PLUS radio has many more features than the Caddy XM, like remembering the last 30 minutes you've listened to and the ability to pause at a drive-thru, etc. Schematics are next to impossible - back in the 80's Delco would share, but not since.
Sirius Satellite... | Answered on Aug 22, 2014
Sirius Satellite Radio Receiver Logo
176 questions posted
Top Sirius Audio Players & Recorders Experts
Anthony Ward
Anthony Ward
Larry Alex
Level 1 Expert
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sirius Audio Players & Recorders
Most Popular Question
only get 184 no other stations
  • Audio Players & Recorders
