What does PF mean on my Hotpoint oven? The lights for the eyes come on but not the heat for oven & eyes. It's an electric oven that I just bought from a friend. Someone mentioned 220 in re: to power???
After a power failure, some models will automatically resume their
setting once the power is restored. On models with a clock, you must reset the clock. If the oven was in use, you must reset it by
pressing the CLEAR/OFF pad, setting the clock and resetting any cooking function.
To Set the Clock
The clock must be set to the correct time
of day for the automatic oven timing
functions to work properly. The time of day
cannot be changed during a timed baking
or self-cleaning cycle.
Touch the CLOCK pad twice.
Touch the + or – pads.
If the + or – pads are not touched within
one minute after you touch the CLOCK pad,
the display reverts to the original setting.
If this happens, touch the CLOCK pad and
reenter the time of day.
Touch the START/ON pad until the
time of day shows in the display. This
enters the time and starts the clock.
To check the time of day when the display is
showing other information, simply touch the
CLOCK pad. The time of day shows until another
pad is touched.
If you do not have the owner's use and care manual,
go to this website and get a free download
of your manual by clicking on your model #.
Once you have downloaded it, you can print it up.
http://sz0047.ev.mail.comcast.net/zimbra/mail#4
Hello & Welcome to FixYa
PF error means power failure which is generally
caused when the control board inside the unit goes bad. You can try unplugging
the unit for 15-30 minutes, if the issue returns then the control board needs
replacement. Please get back to me if you have any other questions.
Kevin
PF means power failure. Did you lose power today or your lights flicker? All electric ovens are powered by 220 volts. They use a special size plug on the cord that's much bigger than the standard 110 volt appliance cord plug.
