20 Most Recent Hotpoint SY36 Style Line Stainless Steel Electric Single Oven Questions & Answers
Hello, bob,.....
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this Informational site may not have your exact model or brand, this site will help you a lot. Here is a site link about everything you want to know about ovens and possibly yours, from
repair to trouble shooting it. Now go easy on me, I am just trying to help. If it does great if not, I am sorry.
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help , I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Hotpoint SY36... | Answered on Dec 29, 2018
If you have a HOTPOINTelectric Cooker or Fan Ovenwhich is not heating it could be one of the following problems.
1, If the fanmotor inthe back of the oven is going round and the temperature light is on (normallylittle red light), but there is no heat then you will probably need a new ovenelement, these are generally very easy to fit and readily available from ourwebsite these can be tested with a electric meter.
To gain access to the HOTPOINTelement youwill have to remove the back plate from inside the oven. Once removed you willsee the fan and element,if you look closely at the element you will probably see a small hole burnt in it where ithas blown. Sometimes however there is no evidence of a fault but the element is open circuitie: broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your HOTPOINTfan oven is getting warm buttakes a very long time to cook or is burning the food more on one side than theother, then you need to check if your oven fanmotor is working you will seethe blade turning fast if it is ok. if the element is heating but the fanmotor isnot blowing the heat into the oven then you need To replace the oven fanmotor is a little more expensive and a bit moreinvolved.
3. If you have theopposite problem ie: your oven is over heating and burning everything then youwill need to replace your HOTPOINToven thermostat
4, A quite commonand easily overlooked answer is if your HOTPOINToven is not working at all ie:no heat and no fan then the chances are that someone has put the oven timer intoAUTO mode, simply put oven back to MANUAL mode and all should be working again.
Hotpoint SY36... | Answered on Dec 02, 2015
If you have a problem with your hotpoint cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Hotpoint SY36... | Answered on Apr 02, 2015
Posted this several years ago. Don't know if it's the same oven. It's possible the oven sensor has gone bad or lost connection. Try cutting out the little plastic electric plug that connects the sensor to the oven wiring. Then hard wire it together with two small wire nuts.
If that doesn't work, you will need a new sensor, as we did. But when we installed it, we used the little plastic electric plug to connect it. Two days later it started acting up again.
The instructions said to hard wire it with two small wire nuts, but since it came with a plug it made sense to use it. Finally, even though it didn't make sense, I cut out the plastic plug and hard wired it. It's been about 3 years now and we've had no further problems.
THERE IS SOMETHING WRONG WITH THAT LITTLE PLASTIC ELECTRIC PLUG. YOU MUST NOT USE IT. HARD WIRE IT.
Hotpoint SY36... | Answered on Mar 17, 2014
Posted this several years ago. It's possible the oven sensor has gone bad or lost connection. Try cutting out the little plastic electric plug that connects the sensor to the oven wiring. Then hard wire it together with two small wire nuts.
Hi there If everything else is working then it's probably the heating element They are not expensive to replace and can be fixed in less than an hr Hope this helps
Hotpoint SY36... | Answered on Nov 22, 2013
The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
Hotpoint SY36... | Answered on Sep 24, 2013
its possible that your element has blown
Hotpoint SY36... | Answered on May 28, 2012
Hotpoint SY36 Style Line Stainless Steel Electric Single Oven Logo
103 questions posted
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
Steve Allison
Steve Allison
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
View Most Popular
Hotpoint Ovens
  • Hotpoint Ovens
Most Popular Question
hotpoint sy36 oven started making
  • Ovens
