20 Most Recent Hotpoint RB757 Electric Kitchen Range Questions & Answers
90 % of Hotpoint range problems will be a loose or broken wire either at terminal block were cord hooks up. check wires from block to stove the wire running up to elements and control board
also check were range plugs into wall it may be loose and not getting good return. burners will work because there is no electronics involved just a infinite switch and coil burner
oven has a computer board for operation.
if you do not find the problem there then change control board
defective relay or computer chip
Hotpoint RB757... | Answered on Mar 24, 2015
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Hotpoint RB757... | Answered on Mar 09, 2015
This may be a silly answer but you might try to just take out the few screws from behind the top panel where the clock is and see what's loose behind there. Unplug the stove first of course.
Hotpoint RB757... | Answered on Feb 25, 2015
I don't know if this will help but I've had to replace heating elements a few times and once it didn't work after replacing the element. It turns out the short also caused one of my electrical wires connecting to the element to burn out as well. This may not be your same deal but make sure you check the wiring. You can also try using a voltage meter or tester to see if power is going to the replaced element. -hope this helps
Hotpoint RB757... | Answered on Jun 12, 2014
Have you put a thermometer in the oven to make sure it is not heating. They will not always glow red if the oven is at temp.
Hotpoint RB757... | Answered on Feb 12, 2014
From having a Hotpoint myself, I can think of 2 possibilities.
Obvious answer would be electrical problem. If it trips the breaker you probably have a loose wire or a bad plugin socket. Did you buy a new "pigtail" plugin socket or did you use an old one when you got the stove? They say to buy a new one each time. If this is your first problem with this then your circuit can probably handle the load but see if the circuit that tripped says 30 or 40 amps. Also check to see if anything else is on that circuit besides your stove. There shouldn't be anything else on circuit. You may even have a bad circuit breaker but that seems less likely.
Second possibility is a bad baking element at the bottom of stove or bad heating element on top. When mine went bad, it made loud popping noises and sparks were flying. After that, the rest of the stove worked but not the baking element. I had to replace it for about $50.
My bet is on a loose wire. Be careful and unplug everything before you check! See if it's not fully plugged into the socket and see if the 3 or 4 wires coming from the thick plug wire are all tightly connected to your stove.
Hotpoint RB757... | Answered on Jan 31, 2014
You should do little more homework.. Yes you can remove the burner if it's the culprit and causes a short and tripping the breakers. If still trips after you remove it you should look into replacing the harness for that burner.
Hotpoint RB757... | Answered on Jan 12, 2014
Replace the bake element and you should be good to go. Here is the part to order.
Hotpoint RB757... | Answered on Oct 20, 2013
you must sure is the burner contacts are o.k or the receptacle is faulty see the diagram 5c7250e3-ba3e-4b5d-944d-b7cdaa1cbc4f.gifb9fcce0a-595b-4298-aa22-aecec61be306.jpg. You must clean the receptacle, and see if some wires and loose or burn, and repair or replace.
However you must sure too if the switches are o.k look for some loose wires or faulty wires and repair, or the switch are faulty test with VOM continuity see the diagram.911164c0-a3fc-4d92-8b45-f3946e75de93.gif
God bless you
Hotpoint RB757... | Answered on Jul 29, 2013
If you disconnect it, you will loose functions to the oven so you will need to replace the clock/control board. Here is the part to order.
Hotpoint RB757... | Answered on Feb 09, 2013
You will need to replace the temperature sensor in the unit. Here is the part to order.
Hotpoint RB757... | Answered on Feb 03, 2013
Hotpoint RB757 Electric Kitchen Range Logo
149 questions posted
Top Hotpoint Kitchen Ranges Experts
Archie Ferrarini
Archie Ferrarini
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Kitchen Ranges
Most Popular Question
long run
  • Kitchen Ranges
