Washer starts then stops and displays f28
hello southerndav4,
Welcome,
you said, you when the unit is started in any cycle it will lock the door and then
run water in for a couple of seconds. It then stops the water and
unlocks and immediately locks again. There is no further action except
the timer counting down until f-28 code. There is no tub rotation and
the ccu was replaced.
I see you did a couple of tests and replaced the CCU!!
You did do what I would have suggested.
You may need to use hands on service this time!
rather than swapping out expensive parts blindly!
Let me know...
Huum
Please remember to leave a rating
This is the condition fo the F28 error code
SERIAL COMMUNICATION ERROR
The communication between the Central Control Unit (CCU) and
the Motor Control Unit (MCU) cannot be sent correctly.
This is what you need to check and or repair
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
Check connections of the CCU board within the housing.
Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing
the MCU connectors.
