Freezers Logo
A
Anonymous Posted on May 09, 2010
Delfield 6000xl: what is the 404a freon charge?
Delfield 6000xl freezer: what is the 404a freon charge?
Dennis Boxerman
Level 3:
  • Freezers Master 1,306 Answers
  • Posted on May 11, 2010
Dennis Boxerman
Freezers Master
Level 3:
Answers
1306
Questions
Helped
647091
Points
2787
Http://www.delfield.com/docs/uploaded/del/Serviceinfo/ref_serv.pdf
this web site has a table of units and their respective charging amounts.
Hope this does it for you.
1 Related Answer
Dennis Boxerman
  • 1306 Answers
  • Posted on Apr 01, 2010
SOURCE: Delfield 6000xl: what is the 404a freon charge?
http://www.delfield.com/?xhtml=xhtml/del/us/en/general/partsandservice/archivemanuals.html&xsl=minisite.xsl
this is for their web site. It has all the manuals and charging tables. There is no 6000xl. Need exact model number as the amount varies.
Hope this helps
Delfield 6000 series 404a, need running pressure in 94 degree kitchen
300-350 on high side. Way too high. Most all commercial unit are built to live in an environment of not more than about 80. Some survive 85. Above that, it's will die due to over working and heating.
Were is the defrost timer
Delfield freezers have defrost in the control. It is a thermostat, defrost control, and other things all rolled into one device. Not adjustable in any way. check the manual for details. http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/6000XL%20SERIES_spm.pdf
What is the suction pressure low side and high side charging 404a refigerant cooling temperature
evap temps usuall run 10-15 degrees below the box temp.This a generally accepted rule of thumb.
Delfield Freezer Model # 6151.S Wiring Diagram
http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/6000XL%20SERIES_spm.pdf. Start here.
1helpful
Service manual for delfield 6151 g
http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/6000XL%20SERIES_spm.pdf. Start with this one.
Hope this helps
Mar 25, 2010 • Freezers
1helpful
Temperature display reading 32 degrees on delfield 6000 xl freezer unit. Should be set for 0. door has been opened one time this morning. Where is display box to check troubleshooting codes located on...
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
There is water leaking out of the front of the unit
Got to be bad gaskets. Get a new gasket from partstown dude.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
