Nordic Track /proform Treadmill Drive/motor Belt 118016 Logo
Posted on May 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for manual for basic nordic track -- basement was flooded
I need a manual for basic nordic track ski machine -- basement was flooded and I think I need to lubricate it but I'm not sure where. Thanks!
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 06, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1761
Points
I have a BC-886 II and found the manual for the Classic Pro Skier (Model NTXC8018) online at Nordic Track's website.
This appears to be the latest version but except for an updated computer it appears to be identical to my older one. (Why mess with a classic?)
Go to http://www.nordictrack.com/ and find the link at the bottom for Parts & Manuals. Enter model NTXC8018 and I think that will give you everything you need.
Hope that helps!
Paul
John Mazmanian
Level 3:
President:
  • Nordic Track Master 832 Answers
  • Posted on May 06, 2010
John Mazmanian
Nordic Track Master
Level 3:
President:
Answers
832
Questions
0
Helped
628621
Points
2056
Go to www.iconservice.com and Input Nordictrack Pro and you will find a manual for your unit
I need BC 887 manual
[DOC]Nordic Track Achiever Manual
188.166.107.131/nordic-track-achiever-manual.doc
... owners manual pro achiever etc ebay , nordic track achiever bc 887 manual ...nordictrack treadmill achiever reviews viewpoints , nordic track skier exercise ...
[DOC]Nordic Track Skier Manual
188.166.107.131/nordic-track-skier-manual.doc
... treadmill manual google sites , ntl nordictrack nordic track c manual sears , nordictrack ntl 1 user manual pdf download , nordic track achiever bc 887 manual ...
achiever bc 887 Treadmills Questions & Answers - Fixya
www.fixya.com > Forum > Tags > achiever bc 887
Treadmills achiever bc 887 questions and answers. Ask your ... Where is the ENTER button? please follow the instr.manual if you do not have it download it from ..
RESISTANCE PROBLEM WITH FREEMOTION 350R
9 out of 10 times the issue is a worn out clutch bearing or "one way needle bearing". Freemotion and Nordic Track are both owned by ICON Fitness. This technology for fitness equipment comes from the original Nordic Track skier. In the skier, there is a flywheel with an axle through it in the middle with skis left and right. Under each ski just about center of the length is a rubber roller that fits over the flywheel axle. Inside this roller is a "one way needle bearing". That is, when you push to the rear with the ski, the bearings rollers will shift and lock against the axle and engage the flywheel. When you pull the ski back forward the rollers inside the bearing release the axle and allow free movent forward untill you again push to the rear. Many poor souls were sold new skis and tension straps in most cases to no avail. What needed to be replaced or rebuilt were the rubber rollers under the center of each ski with the "one way needle bearing clutch" inside. The same technology is used inside this exercise bike except that the "one way needle bearing" is pressed directly into the flywheel itself. So rather that replacing or rebuilding the "roller clutches", you need to replace or rebuild the "flywheel". The price for the flywheel from ICON is $600 plus. Thats right $100 more than you probably paid for the bike. There used to be businesses that rebuilt the roller clutches for the skiers. There is no rebuild service available for the flywheel on this bike. So if you don't buy the maintenance contract witch will cost you as much as the bike for 4 or 5 years you have a very heavy piece of junk to dispose of. This is planned obsolescence at it's best. If you are very handy. You can disassemble the bike and find a commercial machine shop that can replace the bearing for you. It is sandwiched between roller bearings on each end. You will need a press designed to remove and replace bearings for commercial machinery like conveyor belts and assembly line equipment and someone to order and replace the same or an equivalent bearing. This actually should be a relatively affordable service. At least in comparison the only other option.
Nordic track Ski
Dear Sir:
The best way is you go to the next web page:
www.nordictrack.com you must give serial number+modell
whoever i will give another alternative.
www.fitnessrepairparts.com
www.gympart.com
4helpful
Looking to down load user manual for nordic track t7si
The manuals are available at
http://www.iconservice.com/CustomerService/manuals.do
Be sure to have the actual model number (NTTL..., NCTL...) to be sure to find the correct manual.
Nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
Missing a part on the tension belt for a Nordic Track Achiever
Go to Iconservice.com click on manual input Nordic Track Skier their is 47 matches the friction band tensioner should have a clear diagram of that mechanism
Manual for a Nordic Track Personal Performance
Go to iconservice.com click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
Nordic Rower replacement wheel
Nordic Rowers were made by Water Rowers, which still exists and sells parts.
3helpful
I just bought used Nordic Track Elite ski machine. It is stuck in the highest position. The owner said she never figured out how to lower it, but a friend walked up to it a did something and it lowered. I...
Stand on the back of it, facing the front of the skis. You might have to push the button that helps you raise it while you are staning on it. It is a very elegant ride down! Hope this helps.
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
