the fill valve is not letting water in you either have a float that raises up when water is full so when you flush the float drops down letting water in then when water raises it shuts off i would replace the float fill valve and corky flapper.... here is what you do .... first shut water off where it goes up to the tank....... flush commode to empty as much water from tank....... reach up under tank there is a plastic coupling that connects the water supply line to the bottom of the toilet tank...put a small pan under the shut off valve that goes to the toilet some water is going to drain from the tank when you take the coupling loose..... turn the coupling counter clockwise ( use a channel lock adjustable wrench to loosten then had turn) once this is loose you can pull the riser tube away from the tank...... now there is a plastic nut that screws the shaft to the bottom of the tank loosten with channel lock then remove with hand by turning counter clock wise ( you will get a bunch of water flowing down to the pan) remove the entire fill valve , replace with a fluidmaster fill valve ( about 8 bucks from big box store when you take the new fill valve out of the box there is a neopreme seal you must put on the new threaded shaft ( it has an inner ring you may have to punch out) once you put this on you can insert the entire shaft down through the hole in tank then secure with thin nut provided tighten but do not overtighten then put coupling back on,,,,,put the over flow tube on the tit of the fill valve and stick down into over flow ok thats done when you go to big box store purchas a 5 buck corky flapper (red caus it can handle chlorine water better) remove the old one at bottom of tank( just two clips to remove and chain attached to flush lever...install new one be shure chain does not have a lot of slack so it does not fall under flapper seal when you flush......OK YOU ARE DONE TURN WATER ON WATCH TANK FILL LOOK FOR LEAKS TAKE A TOWEL AND DRY ALL AREAS THEN TAKE YOUR HAND AND FEEL FOR LEAKS UNDER TANK AND DOWN TO SHUT OFF VALVE .....CONGRATS YOU DID IT!
A couple of thing's to check the fill tube in the tank is it connected from the fill valve to over flow. This fill's th ebowl up with the required amount of water.
Next is the water filling to the line on the fill tube with in 5/8 " from top of tube. Adjust the float to get it with in the fill amount required.
The chain on the flapper need's some slack, you just have to move it a little till it get's adjusted right. Water level low in the tank will affect the flapper also.
The fill valve needs replacement unless you can take the top off snd find out what is keeping it from closing. I had one I took apart for the same reason and found a piece of plastic in the valve seat. Good Luck, Ned
all parts are replacable in any toilet, don;t know the number you have on here but am assuming it's the douglas valve the center valve that has the hose going into it,,, if this is it call kohler and they will send you the part, you may have to remofve the tank wich there are 3 bolts that hold the tank to the bowl,,,,,
It may be that the fill tube has come disconnected . It runs from the top of the fill valve to the overflow. The overflow is the tube that runs up the middle of the tank. The fill tube runs from the top of the fill valve to the top of the overflow tube. Kohler has a little clip that can sometimes come undone and cause spraying.
If that doesn't do it, turn the water off to the toilet and take off the tank lid. Partially open valve ( Slowly). Locate where spray is coming from. If it is in the area on top of the fill valve then yes, buy anew one. ( Fluidmaster )
This type of flush system can be re presurised quickly by holding down the flush handle for about good 2 minutes, then release , wait for the tank to be refilled with water. Now you can flush away your inner rotting mess down tube good-by...
