20 Most Recent
Kohler K-11465-0 White Cimarron Comfort Height Complete Solution rou Questions & Answers
My Kohler Cimarron has a
Probably something stuck in the Trap of the stool unless your main line is stopped up. If you cannot plunge it, you may have to take the stool loose from the floor, unhook the water line, and turn it upside down out in your yard. You will be able to view right up into the trap of the stool . Otherwise, you can go buy a small stool snake and try to root it out on your own. Good luck, this is no fun.
My Kohler 11465 flush handle
Loosen the nut that holds it in. The nut is inside the tank and is left hand threads. Or it may need a new one if any of the plastic is broken or cracked.
After the tank fills water contiues to flow thru
The fill valve needs replacement unless you can take the top off snd find out what is keeping it from closing. I had one I took apart for the same reason and found a piece of plastic in the valve seat. Good Luck, Ned
Water continues to run but
There is a screw threaded adjuster on the float to adjust the height at which the shut off valve operates.
Lower the float a bit by rotating it clockwise.
If the valve still does not shut off you probably need to replace the rubber sealing washer - buy a proprietary service kit from any good DIY store.
Turn off water at isolator valve (or at mains / cold water tank)
Unscrew the body of the shut off valve carefully, making sure that any springs do not ping out. Replace sealing washer and reassemble.
TOILET LESS THAN 1 YEAR OLD 2ND TIME THIS HAS
Sounds like you need to have the drain line augered out to remove an obstruction.
A plumber, or a roto-router type service will be needed if you don't know how to do it yourself.
Good Luck.
Need password for a stolen file
Okay. The question is a bit lacking in details. Password for what? Password ON what? Where was the file stolen from? Who stole the file? What is the file content. What is the file extension (the bit after the file name and the period file_name.what)?
All questions need to start 'make model (what it is)' first 3 words. And then a clear question.
For the 13 people that have tagged this 10 year old question, it is better to post your own question.
2/7/2024 6:03:08 AM •
Kohler Home
Answered
on Feb 07, 2024
