I descaled the machine and when I finished the lights keep flashing and I have to switch them on and off manually. Can I fix this?
SOURCE: After descaling le Cube two flashing buttons won't stop so can't
I had the same issue. This is what a did:
Turn off the machine
Remove the tray/container and leave it outside
Turn on the machine and this time the power button should be flashing (preheating) then hold both cup buttons for 3 sec and it will be back to normal opertion....
For some reason the sensor needs to read that the tray/container is out of the machine...
SOURCE: keurig coffee maker does not make a full cup,
Check the needle to make sure it's not clogged. You can completely remove the k-cup holder and wash it out with your kitchen sink sprayer to help remove any obstructions. The manufacturer even recommends using the tip of a small paper clip to help push out any debris if needed. Then try brewing a cup of just water on the largest setting without a k-cup in it. Hope that helps! Best of luck...
SOURCE: the small and large cup buttons are alternatly
I had the same problem and was told it needed to be repaired by Nespresso and the cost would be 115 euros.
Testimonial: "Thank you, Yes, Nespresso said that same to me, I didn't have it fixed I could have had a refurbished one for $100 or receive $125 off a new machine. "
SOURCE: My keurig machine wasn't brewing a full cup so I
do another descale..add more vinegar....run the entire full tank of water....you must have a big buildup of scale...
In order to keep your Tassimo machine
operational at full order, it is important to descale it every three
months. Descaling products are widely available from stores that sell
coffeemakers and espresso machines. Be sure that the product you buy to
descale your Tassimo machine is intended for this specific use only. Mix
the descaling product directly in the water container, following the
instructions provided on the descaling packaging. Then replace the water
container on the machine. Place a large cup or mug on the cup stand,
insert the cleaning disc, bar code down and close the brew mechanism. As
soon as the AUTO light illuminates, press and release the start/stop
button. This will fill the brew cycle with descaling solution. Empty the
cup and let the machine stand for 15 minutes. Then open the brew
mechanism and close it again, leaving the cleaning disc in place. Repeat
this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water
container, rinse it well and refill with fresh, cold water. Clean the
machine by flushing water through it in the same manner and emptying the
cup as it fills. Make sure that all the descaling solution has been
completely rinsed away, and then flush two full water containers through
the machine before using it again. Remove the cleaning disc, rinse and
refill the water container and your Tassimo machine is ready to use.
Also, before you descale your Tassimo machine, always unplug it. Also,
never immerse the appliance in water and nor should you use abrasive
cleaning products or scouring materials on any part of your Tassimo
machine. This method works for most espresso machines,
including some of these popular models: the DeLonghi Magnifica
EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400,
Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi
PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
