20 Most Recent Gaggia Syncrony Compact Coffee Maker/Espresso Machine Questions & Answers
How can reset my miele cva 620
To reset your Miele CVA 620 coffee machine, you will need to perform a "Reset Water Hardness" procedure. This will reset the machine's water hardness settings and clear any error codes that may be displayed on the control panel. To perform a "Reset Water Hardness" procedure, follow these steps:
  1. Press and hold the "Menu" and "Coffee Bean" buttons simultaneously for 5 seconds.
  2. Release the buttons and press the "Menu" button again.
  3. Use the "Coffee Bean" button to navigate to the "Reset Water Hardness" option and press the "Menu" button to select it.
  4. Follow the prompts on the control panel to reset the water hardness settings.
After the "Reset Water Hardness" procedure is complete, your Miele CVA 620 coffee machine should be reset and any error codes that were displayed on the control panel should be cleared.
1/2/2023 4:43:38 PM • Gaggia Syncrony... • Answered on Jan 02, 2023
2answers
Gaggia Syncrony does not get past the grind cycle
Water has probably been spilt in the beans area. The grinder needs cleaning out along with the chute
8/21/2018 3:29:54 PM • Gaggia Syncrony... • Answered on Aug 21, 2018
GAGGIA SYNCRONY LEAKING FROM THE WATER TANK.
replace seal
9/5/2017 1:12:15 PM • Gaggia Syncrony... • Answered on Sep 05, 2017
No water comes out on ventilate. At first, the
Hi
It should take about 45 minutes to an hour to properly descale the machine. If it only took a couple of minutes you really didn't descale your machine. If you used the powder it has to disolve completly before descaling. The best way to descale is with the descaler in the tank. Turn on the machine and run about 8 ozs of water-descaler through the wand and then turn off the machine. Wait 10 minutes and repeatthe last procedure. Do this until the tank is empty. When done with the descaler, rinse out the tank and put fresh water in the tank and run the whole tank through the wand. Then fill the tank and your ready to go.
11/19/2016 5:59:20 PM • Gaggia Syncrony... • Answered on Nov 19, 2016
When I turn on the coffee machine flashing red button calcing. and 'put in a container for water descaling solution., when I hold the button for more than 5 seconds nothing happens.
push it for 5 second and if its still flashing doesn't matter turn the steam knob anti-clockwise end let the machine do to the descaling cyrcle, when then water tank emptied the rest of buttons starts to flashing, turn the knob off and your machine is ready!!
4/19/2015 5:02:04 PM • Gaggia Syncrony... • Answered on Apr 19, 2015
2answers
The coffee dispenses really slowly.
if our coffee drip try to ajust how fine you grind and amount of coffee if you grind the cooffee to fine its hard for the pressure water to go truh and clean the machine with a decalcifier to remove the calcium buildup more calcium less pressure you have to clean the machine every other mounth cheers
10/9/2014 2:05:57 PM • Gaggia Syncrony... • Answered on Oct 09, 2014
2answers
Syncrony digital gaggia coffee maker leakage+ventilate message
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
8/30/2014 3:32:23 AM • Gaggia Syncrony... • Answered on Aug 30, 2014
2answers
Gaggia Compact Synchrony (2005)
If you water from steam water wand then machine is clean from water pump and boiler. The blockage is after the boiler and on two most posible points.
The first point is the coffee valve which it migh be blocked from dry coffee which is acting like a glue. At the link below
http://www.partsguru.com/user/ER0176_Rev01.pdf
you will find the part diagram of your machine. the coffee valve is injector who conects the coffee group and it consist from parts from number 42-49 page 2/3. This will need to be removed and sink in warm water for 30 minutes and be clean well and put back on the machine.
Second posible is the coffee group which again you can remove the coffee filter from the group piston, is the st. stell disk with small holes all over it and itsecure in the center with a screw, so by removing this center screw you can clean the disk and the holes under it with warm water so all the dry coffe will be resolve and removed.
6/23/2014 8:38:12 PM • Gaggia Syncrony... • Answered on Jun 23, 2014
Gaggia syncrony compact will not switch on
I have had this problem. The main switch on the machine burned over and I had to take it to a maintenance to put a new on. I do not know if there is a fuse on the machine. It was not in my case anyway.
5/29/2014 8:36:18 AM • Gaggia Syncrony... • Answered on May 29, 2014
0answers
Coffee out of the machine seems too watery
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
4/14/2014 8:15:18 AM • Gaggia Syncrony... • Answered on Apr 14, 2014
0answers
Water tank
Be the first to answer 3/23/2014 3:05:56 AM • Gaggia Syncrony... • Posted on Mar 23, 2014Be the first to answer
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
149 questions posted
Top Gaggia Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Gaggia Coffee Makers & Espresso...
  • Gaggia Coffee Makers & Espresso...
Most Popular Question
gaggia syncrony digital
  • Coffee Makers & Espresso Machines
