Canon makes it ******* owners by using a small electronic chip on each cartridge that opens when it is taken out of the printer. Sometimes removing a cartridge will not open and when replaced in the print head, it works, but if the cartridge sensor fails to communicate with the printer, you would need a resetting device to bring the cartridge back to normal. Rather than become upset with the issue, it would be best to get a new cartridge from any reseller on the internet (not Canon) and go from there.
SOURCE: Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
SOURCE: Missing Colors
This is a simple problem just reset your printer's color management settings!!!!!!!!!!!!!!!!!!!! :-)
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
SOURCE: Canon pixma 400 multifuncxtion Last
Hi, I went local and found that to fix the problem would cost a lot to time and much money, so I bought the later model at half the price of my old one purchased one year and three weeks ago. Thank you for replying.
SOURCE: Canon PIXMA MP210 Problem:Orange Alarm light
Ok, the paper jam could be due to one of the following:
If there is no bit of paper or
debris stuck in the rollers, it would indicate something more serious,
and in need of servicing. If your machine is under warranty, I suggest
you take it back to the shop and get it replaced.
If your warranty
has run out, then you'll either have to get it serviced or buy a new
printer (whichever works out cheaper for you)
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
