howdie well for start check to see if the gas is fresh and that the filter is clean some don,t run if the oil is low put in a new plug go get won at your local shop and it should gohowdie well for start check to see if the gas is fresh and that the filter is clean some don,t run if the oil is low put in a new plug go get won at your local shop and it should go
AnonymousMar 14, 2014
Having a hard time trying to find out size and routing of drive belt on 20 HP HUSKEE RIDING lawn tractor...need help pleaseHaving a hard time trying to find out size and routing of drive belt on 20 HP HUSKEE RIDING lawn tractor...need help please
You can't post conmments that contain an email address.
? 7:33 www.youtube.com/watch?v=_dzcDZUh1MY May 10, 2013 - Uploaded by mountainbikekayak
But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sounds like a fuel problem. Clean the carb good using fine wire and be sure to clean all of the small passages. Fresh gas and a new new fuel line can do wonders.
This engine is one of Briggs & Stratton`s basic engines, quite a simple engine, post your problem and i`ll answer,
If you really feel that you need a manual they are available through some outlets, try Wal Mart. or ebay
first check to see if you have good clean gas in it. No water. if you have good clean gas. then I would recomend taking the gas tank off wich should have a plastic carburetor mounted to it. after that is removed and free of excess dirt. take the carb off there should be 5 phillips head screws. pull the carb off gently while observing just how it all goes back together. you may want to take pictures. you will find a fuel screen that you should take off and clean with carb spray. also there is a fuel pickup tube clean that also with carb spray. a couple words of caution if using compressed air Do not carried away with it. also same with the carb cleaner to much of it in rubber primers is not good.
