Sewing Machines Logo
Posted on Mar 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Viva Limited edition-need help with free motion foot
I have a Viva Limited Edition. I bought a snap on free motion foot part number 412860645. I have played with different tensions and cannot get the right combo to do free style quilting. This is so frustrating. Help!!!
Douglas Plant
Level 2:
Champion:
  • Expert 222 Answers
  • Posted on Apr 14, 2010
Douglas Plant
Expert
Level 2:
Champion:
Answers
222
Questions
Helped
64185
Points
402
Try running the machine at a faster speed, teh most common error new quilters maake is moving the fabric too fast and the machine too slow.
How do I set the Husqvarna 300 sewing machine to do free motion embroidery. Do I need the embroidery attachment and get the machine to embroider with or with out the card
You can do embroidery or you can do free motion. If you're quilting a quilt sandwich (fabric, batting, backing fabric), you probably want to do free motion quilting. Embroidery would work better on fabric (with a stabilizer) but without the batting and backing fabric.
For free motion, you want a free motion foot--your machine's manufacturer probably provided one in the accessory kit (called a darning foot) or there are many generic free motion feet available for purchase (ie Big Foot quilting foot...). The BIG difference with a darning foot or free motion foot is that the shank is shorter than other presser feet because there needs to extra space between the presser foot and the needle plate so the quilter can easily manipulate the fabric. Usually, free motion quilters will drop the feed dogs to avoid feed dog interference with the fabric's movement, however, some quilters don't drop the feed dogs--just whatever works best for you and your machine. In addition, I use a Supreme Slider on the sewing machine surface--a silicone mat that provides a slick surface to help the fabric move.
There are a lot of web sites and video tutorials on free motion quilting. Take some time to watch them and then practice, practice, practice! It's an acquired skill so the more you practice, the better you will be.
Does the singer 533 have either a walking foot, a patchwork foot, or a quilting foot
You should be able to find some, if not all, of the presser feet you mention. You just need to determine what shank your machine has and make sure the presser feet you purchase have that same shank. (You may even have a snap-on adapter for your machine, so you just need to order the snap-on feet you want.)
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
Singer 533 Stylist Parts
Free Motion Quilting Foot for ALL SINGER KENMORE
Does the 4562 singer deluxe freearm electronic speed control 32 stitch function come with a freemotion foot and do the feeddogs drop?
Most machines include a "darning" foot, which is the equivalent of a free motion foot. However, there are multiple choices of free motion feet that can be purchased elsewhere which are made of various materials, in different shapes, and also with springs to create bounce--just something to consider, but not necessary.
Your machine should either have the ability to drop the feed dogs, or a cover plate that snaps over the feed dogs to prevent them from contacting the fabric when free motion quilting.
Your manual should have information as to what is included.
Instruction Manuals
How do I set up my Janome 1600p-qc for free motion quilting?
You will need a darning foot or free motion quilting foot for your machine (these feet are shorter than the regular feet which allows space between the foot and the needle plate to manually manipulate your fabric). Then drop the feed dogs and, if your machine does not have that capability, there should be a cover plate included with your machine that snaps over the feed dogs. Install a brand new needle in your machine, set it for a straight stitch, and test the stitch. Sometimes, the upper tension needs to be loosened a bit so the bobbin thread does not poke through the top of the fabric.
Then...practice, practice, practice...
How to Free Motion Quilt on Regular Sewing Machine
Free Motion Quilting Beginner Tutorial 1 of 4
FWIW, I've found it helpful to use a "Supreme Slider" on the base of my machine. It is slick and allows the fabric to move easily. Special gloves are helpful too because your hand will become dry and begin to slip on the fabric. Using cheap rubber gardening gloves works for some people.
supreme slider Google Search
quilt gloves Google Search
1helpful
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
2answers
I have a Sears Kenmore sewing machine I want to get a 1/4 in presser foot for it, is there one and where would I get it/
You first need to determine which shank the presser foot uses on your machine. You can compare your shank (current presser foot) with these photos to see which one your machine uses.
NOTE: If you purchase a snap-on presser foot, you will also have to buy a "shank adapter" that will attach the presser foot to the needlebar. Here are some pictures of snap-on adapters:
Kenmore sewing machine snap on adapter Google Search
However, you will still need to make sure to buy the correct adapter for your machine. The GREAT thing about buying a snap-on adapter is you can add a lot of presser feet to your sewing machine accessories because you can purchase additional snap-on presser feet or even a complete set of snap-on feet that will all work with your adapter and your machine!!!
Kenmore Presser Feet eBay
You will just snap one foot off and snap another on!!! Great idea!!!
OR--you can take your current presser foot along with the make & model of your machine and check with the local sewing repair shops to see if they have what you need.
FYI, once you know what shank your machine has, you can probably also find other specialty feet for your machine, ie walking foot, free-motion foot, etc.
2answers
Which foot do I use for quilting
a quilting foot or buy one with a round hole in it great
My threader piece popped off
If you are referring to the needle threader, there is a screw on right side to loosen when inserting needle. Tighten it back.
If you are referring to the needle foot, there should be a little flipping switch that releases foot. Place foot in place, lower needle arm and if aligned properly, foot will snap back on/into position.
The foot pedal seems to have no power.
if the foot pedal is plugged into the sewing machine correctly, then it would be a good idea to have the foot pedal check to see whats wrong with it and they can advise you wether to have it fixed or just replace it
Top Husqvarna Sewing Machines Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
