20 Most Recent Brother XR9500PRW Limited Edition Project Runway - Computerized Sewing Machine 100 Built-in Stitches, Quilting Table Questions & Answers
I have brother computerized machine.its making noise at the hand wheel.i noticed that when I manually turn the hand wheel away from me it doesn't make noise n the same rotations when I turn towards me
Is the needle hitting the metal plate on the way down? If so, take out the needle and reload it, maybe it is just a little out of position.
5/4/2015 12:04:09 AM • Brother... • Answered on May 04, 2015
How do I set the stitch length and width. Have been doing as the manual said and doesn`t seem to work.
Sometimes you also need to change the foot as well for monogramming. Do check this in the manual.
3/27/2015 11:57:15 PM • Brother... • Answered on Mar 27, 2015
Please show me how to loosen the two pressure plate screws on the xr9500xrw brother sewing machine
A coin like a loonie or a silver dollar fits the screws better than any screwdriver. The screws are put in by machine in the factory, they are very tight, use your muscle power. You don't have to tighten them too much when you replace them. I'm a Brother dealer, that's how we do it.
12/4/2014 12:25:46 AM • Brother... • Answered on Dec 04, 2014
My brother exedra e-40 #db2-b737-413
  1. In the event that changing the needle didn't determine the issue, have a go at rethreading the machine, guaranteeing legitimate pressure, and cleaning the bobbin region for any build up or garbage. On the off chance that the issue continues to happen, consider counseling the machine manual or looking for proficient help.
2/12/2024 2:00:07 AM • Brother Sewing... • Answered on Feb 12, 2024
Brother DB2-B755 Mark III-3A Sewing Machine. How do I reset 03 on my Mark 111 machine?
Question edited for clarity. A DB2 is a car made by Aston Martin, but this appears to be a sewing machine. All question need 'make model (what it is)' as first 3 words please. Question moved from Computers category to Brother Sewing. This is the only resource I can find for Brother Error 03 E03 Cause This message is displayed when the buttonhole lever is up, a buttonhole stitch is selected, and a button, such as the "Start/Stop" button, is pressed. Solution Lower the buttonhole lever before continuing the operation. https://www.google.com/search?q=Brother+DB2-B755-3A+mark+111+error+code+03 ..
2/9/2024 6:36:47 PM • Brother Sewing... • Answered on Feb 09, 2024
2answers
DOES THE BROTHER PROFILE 821 SEW LEATHER??
go to the website of leatherworker.net and check with them
1/3/2024 3:21:55 PM • Brother Sewing... • Answered on Jan 03, 2024
Brother VX-810 Sewing Machine presser foot will not go up?
Question edited for clarity add maker. Question moved to maker category. https://www.google.com/search?q=Brother+VX-810+Sewing+Machine+presser+foot+will+not+go+up ..
11/26/2023 10:26:11 PM • Brother Sewing... • Answered on Nov 26, 2023
Brother innovis 1500 D embroidery unit starts to move then chatters and stops
Hi, the only reason I can think of is that it might be the fan belt that moves the arm that is causing the problem. Best to take it in to a professional to look at it for you. Good luck
11/25/2023 3:29:34 AM • Brother Sewing... • Answered on Nov 25, 2023
Brother innovis le cant get scanned picture off previous design
Hello Tarakeira Here is an electronic manual at http://www.manualagent.com/brother/innov-is-750e/users-manual/page-10 It is for for the 750E, but will be useful for your instance. Happy Sewing
11/25/2023 3:24:34 AM • Brother Sewing... • Answered on Nov 25, 2023
Am helping a neighbor who has a cheap Brother sewing machine, the needle does not seem to be centered, the default is to the right. I can center it by changing the needle position.
Some machines do not have a centered needle as a default. That is just how they were made. If she can reposition the needle to the center, then that is a pretty good option. Most older machines with the offset needles default do not have a centering option. (I have an old Nelco that has an offset default--works just fine but I just have to remember that when stitching, the seam line will not be in the center of the presser foot.)
11/18/2023 1:45:09 AM • Brother Sewing... • Answered on Nov 18, 2023
Brother PR655 Entrepreneur Embroidery Machine. Y-axis home position error on PR655.
Question edited for a lot more clarity. Question moved from Office Equipment category. Service manual refers https://www.manualslib.com/manual/1353673/Brother-Pr655.html?page=282 ..
11/15/2023 6:48:55 PM • Brother Sewing... • Answered on Nov 15, 2023
Manual for a brother 273c
You can download required manual from this page Home Sewing Machine ' United States ' Brother support website
10/24/2023 1:38:48 PM • Brother Sewing... • Answered on Oct 24, 2023
Brother Super Galaxie 3000. How do you adjust the hook timing please?
It is a skilled job and best left to a service tech, but here is the service manual and some videos.Page 34 refers.https://acmerevival.com/wp-content/uploads/2021/07/smM3000.pdf
9/25/2023 5:07:46 PM • Brother Sewing... • Answered on Sep 25, 2023
2answers
Brother XL5600 is not stitching properly and dropping stitches?
need to check the hook timing. put it in zig zag, no fabric, turn the hand wheel to you slowly. check the needle when it is coming back up, is the hook picking up the thread? if yes continue to check the next side, so if you check the left side then check the right. if any side its not picking up the thread then the timing is off and need to be retimed
9/21/2023 9:02:32 PM • Brother Sewing... • Answered on Sep 21, 2023
Brother XR9500PRW Limited Edition Project Runway - Computerized Sewing Machine 100 Built-in Stitches, Quilting Table Logo
6 questions posted
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Brother Sewing Machines
Most Popular Question
brother sewing machine keeps showing
  • Sewing Machines
