20 Most Recent
Brother CE8080PRW Limited Edition Project Runway Sewing Machine Questions & Answers
Thread tension will not adjust.
Check your setting, you have your stitches set too far apart. Wherever on your machine you see the zigzag stich you will see other stich settings, look at it until you see the right amount of stiches you want.
3/9/2017 5:04:05 PM •
Brother...
Answered
on Mar 09, 2017
My knob at the end of my machine is frozen
Are you talking about the flywheel? The knob that turns when you are stitching? If that is the problem, then there is something bound up in y our machine. Unthread the whole thing. Will it turn? If not, take out the bobbin and try to turn it Check your needle to see if it is bent. If none of these work you will probably have to take it in for service. I recommend finding an independent repair shop rather than a sewing machine store. They are considerably less expensive, and can get the work done in a fraction of the time. Best wishes to getting back to sewing!
12/8/2013 8:14:07 PM •
Brother...
Answered
on Dec 08, 2013
Brothers com
. try eBay - seller who is selling new Brother machines.
10/19/2013 1:02:18 PM •
Brother...
Answered
on Oct 19, 2013
My threader piece popped off
If you are referring to the needle threader, there is a screw on right side to loosen when inserting needle. Tighten it back.If you are referring to the needle foot, there should be a little flipping switch that releases foot. Place foot in place, lower needle arm and if aligned properly, foot will snap back on/into position.
8/29/2013 10:51:35 PM •
Brother...
Answered
on Aug 29, 2013
