Polycom SoundPoint IP 501 IP Phone Logo
Posted on Mar 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to add the more softkeys in sound point ip 501
Anonymous
Level 2:
New Friend:
  • Expert 137 Answers
  • Posted on Mar 30, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
137
Questions
0
Helped
35493
Points
229
Need to buy one soft keys station and that will connect to your master's.
How do i configure mms on nokia C3-01?
1. Press the Menu button 2. Highlight 'Messages', then press Select 3. Highlight 'Message settings', then press Select 4. Highlight 'Multimedia msgs.', then press Select 5. Check that 'Save sent messages' is set at 'No'. 6. Check that 'Delivery reports' is set at 'No'. 7. Check that 'Allow multimedia reception' is set at 'In home network'. 8. Check that 'Incoming multi-media messages' is set at 'Retrieve'. 9. Highlight 'Connection settings', then press Select 10. Highlight 'Active multimedia settings', then press Select 11. Highlight the next available Set (e.g. Set 1), then press Activate 12. Highlight 'Edit active multi-media settings', then press Select 13. Highlight 'Settings' name' and press Select (left softkey). Enter 'giffgaff MMS', then press OK 14. Highlight 'Homepage', then press Select (left softkey). Enter 'http://mmsc.mediamessaging.co.uk:8002' and press OK 15. Highlight 'Session mode', then press Select (left softkey). Highlight 'Permanent' and press Select 16. Highlight 'Data Bearer', then press Select (left softkey). Highlight 'GPRS' and press Select 17. Highlight 'GPRS access Point', then press Select (left softkey). Enter 'giffgaff.com' and press OK 18. Highlight 'IP Address', then press Select (left softkey). Enter '193.113.200.195' and press OK 20. Highlight 'Authentication type', then press Select (left softkey). Highlight 'Normal' and press Select 21. Highlight 'User name', then press Select (left softkey). Enter 'giffgaff' and press OK 22. Highlight 'Password', then press Select (left softkey). Enter 'password' and press OK 23. When asked to 'Verify new password' enter 'password' and then press OK 24. Press Back (right softkey) 6 times to return to the standby screen.
W580i gprs setting vodafone postpade
Settings - GPRS WAP
Sony Ericsson W580i GPRS WAP Pay & Go settings
Please note all steps must be completed to ensure the settings are correctly configured.
Please ensure that when entering 'O2' into the settings that the letter 'O' is selected not a zero.
The W580i has a central navigation button (Navi key) and two soft keys slightly above this.
1. Press 'Menu' (right softkey).
2. Highlight 'Settings' and press 'Select' (left softkey).
3. Scroll to the 'Connectivity' tab by pressing the Navi key to the right.
4. Scroll to 'Data communication' and press 'Select' (left softkey).
5. Highlight 'Data accounts' and press 'Select' (left softkey).
6. Highlight 'New account' and press 'Add' (left softkey).
7. On the 'Account type' screen, highlight 'PS data' and press 'Select' (left softkey).
8. On the 'Account Name' screen, enter 'O2 WAP GPRS', press 'Continue' (left softkey).
9. On the 'New PS data' screen, highlight 'APN' press 'Edit' (left softkey), enter 'payandgo.o2.co.uk' and press 'OK' (left softkey).
10. Highlight 'Username' press 'Edit' (left softkey), enter 'payandgo' and press 'OK' (left softkey).
11. Highlight 'Password' press 'Edit' (left softkey), enter 'password' and press 'OK' (left softkey).
12. Press 'Save' (right softkey).
13. Press the 'back' arrow key (key directly below left softkey) 2 times.
Activate GPRS settings:
14. Highlight 'Internet settings' and press 'Select' (left softkey).
15. Highlight 'Internet profiles' and press 'Select' (left softkey).
16. Highlight 'New profile' and press 'Add' (left softkey).
17. Highlight 'Name:' press 'Add' (left softkey), enter 'O2 WAP GPRS' and press 'OK' (left softkey).
18. Highlight 'Connect using' press 'Select' (left softkey), highlight 'O2 WAP GPRS' and press 'Select' (left softkey).
19. Press 'Save' (right softkey).
Change GPRS settings:
20. Highlight 'O2 WAP GPRS' and press 'More' (right softkey).
21. Highlight 'Settings' and press 'Select' (left softkey).
22. Ignore 'Connect using'
23. Highlight 'Use proxy:' press 'Select' (left softkey), highlight 'Yes' and 'Select' (left softkey).
24. Highlight 'Proxy address:' press 'Edit' (left softkey), enter '193.113.200.195' (to bring up the number press the number until it appears. Add the dots with the '1' key) and 'OK' (left softkey).
25. Highlight 'Port number:' press 'Edit' (left softkey), enter '8080' and press 'OK' (left softkey).
26. Highlight 'Username' press 'Edit' (left softkey), enter 'payandgo' and press OK (left softkey).
27. Highlight 'Password' press 'Edit' (left softkey), enter 'password' and press OK (left softkey).
28. Press 'Save' (right softkey).
Change Homepage:
29. Highlight 'O2 WAP GPRS' and press 'More' (right softkey).
30. Highlight 'Advanced' and press 'Select' (left softkey).
31. Highlight 'Change homepage' and press 'Select' (left softkey).
32. Highlight 'Name:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'O2 ACTIVE' and press 'OK' (left softkey).
33. Highlight 'Address:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'http://wap.o2.co.uk' and press 'OK' (left softkey).
34. Press 'Save' (right softkey).
35. Press the backward arrow key (key directly below left hand soft key).
36. Highlight 'O2 WAP GPRS' and press 'Select' (left softkey).
37. Press the 'back' button (to left of Navi key) 3 times to return to the standby screen.
Vodafone live postpade gprs setting w580i
8. On the 'Account Name' screen, enter 'giffgaff WAP GPRS', press 'Continue' (left softkey).
9. On the 'New PS data' screen, highlight 'APN' press 'Edit' (left softkey), enter 'giffgaff.com' and press 'OK' (left softkey).
10. Highlight 'Username' press 'Edit' (left softkey), enter 'giffgaff' and press 'OK' (left softkey).
17. Highlight 'Name:' press 'Add' (left softkey), enter 'giffgaff WAP GPRS' and press 'OK' (left softkey).
18. Highlight 'Connect using' press 'Select' (left softkey), highlight 'giffgaff WAP GPRS' and press 'Select' (left softkey).
20. Highlight 'giffgaff WAP GPRS' and press 'More' (right softkey).
Change Homepage:
29. Highlight 'giffgaff WAP GPRS' and press 'More' (right softkey).
32. Highlight 'Name:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'giffgaff ACTIVE' and press 'OK' (left softkey).
33. Highlight 'Address:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'http://giffgaff.com/mobile' and press 'OK' (left softkey).
36. Highlight 'giffgaff WAP GPRS' and press 'Select' (left softkey).
The GPRS WAP settings are now complete.
Sony Ericsson W580i MMS
You'll need to complete all steps for this to work.
Please also ensure the GPRS WAP settings have been entered prior to entering the MMS settings.
2. Highlight 'Messaging' and press 'Select' (left softkey).
3. Scroll to 'Settings' and press 'Select' (left softkey).
4. Highlight 'Picture message' and press 'Select' (left softkey).
5. Highlight 'Validity period' and press 'Edit' (left softkey), highlight 'Network maximum' and 'Select' (left softkey).
6. Highlight 'Read report' and press 'Edit' (left softkey), highlight 'Off' and 'Select' (left softkey).
7. Highlight 'Delivery report' and press 'Edit' (left softkey), highlight 'Off' and 'Select' (left softkey).
8. Highlight 'Signature' and press 'Edit', highlight 'No signature' and 'Select' (left softkey).
9. Highlight 'Creation mode' and press 'Edit' (left softkey), Highlight 'Unlimited' and 'Select' (left softkey).
10. Highlight 'Picture scaling' and press 'Edit' (left softkey), highlight 'Off' and 'Select' (left softkey).
11. Highlight 'Auto download' and press 'Edit' (left softkey), highlight 'Ask in roaming' and 'Select' (left softkey).
12. Highlight 'Accept messages' and press 'Edit' (left softkey), if not already ticked highlight 'Advertisements' and press the left hand soft key 'Mark'. If already ticked leave. Ignore 'Anonymous' Press 'Save' (right softkey).
13. Highlight 'MMS profile' and press 'Edit' (left softkey).
14. Highlight 'New profile' and press 'Add' (left softkey).
15. Highlight 'MMS profile name:' and press 'Edit' (left softkey), enter 'giffgaff MMS', select 'OK' (left softkey).
16. Highlight 'Message server' and press 'Edit' (left softkey), enter http://mmsc.mediamessaging.co.uk:8002' and press 'OK' (left softkey).
17. Highlight 'Internet profile' and press 'Edit' (left softkey), highlight 'giffgaff WAP GPRS' and press 'Select' (left softkey).
18. Select 'Save' (right softkey).
19. Highlight 'giffgaff MMS' and select (left softkey).
20. Press 'back arrow' (key to left of navi key) 5 times, to return to standby screen.
The MMS settings are now complete.
Soundpoint ip 501 cannot acees via browser
Are you using config files loaded from the server? If so, make certain they are properly configured. Also, make certain the phone does not already have an alternate configuration in it that points elsewhere...
1helpful
How to unlock cisco ip phone 7910
  1. Press **# in order to unlock Network Configuration on the phone.
  2. Press Settings.
  3. Press 3 on the keypad (or scroll down) for Network Configuration.
  4. Press 33 on the keypad (or scroll down) for Erase Configuration.
  5. Press the Yes softkey.
  6. Press the Save softkey.
HOW DO YOU CHANGE THE PASSWORD ON THE MITEL 5220 IP
1. Press SUPERKEY.
2. Press the No softkey until "Set Password?" appears.
3. Press the Yes softkey.
4. Do one of the following:
?? To enter a new password, enter your password.
?? To change or clear your password, enter your current password.
5. Press the Enter softkey.
6. If you are changing or clearing your password, do one of the following:
?? To change your password, enter your new password and press the
Enter softkey.
?? To clear your password, enter 0.
7. Enter your new password again.
8. If you are setting up or changing a password, press the Enter softkey.
9. Press SUPERKEY.
2answers
How setup internet settings
The phone has a 4-way directional 'Navi' key and 2 soft keys on either side of this. The Navi key can also be pressed in to select options.
1. Press the 'i' button (press navi key).
2. Highlight 'Browser' and press 'Select' (left softkey).
3. Highlight 'Browser settings' and press 'Select' (left softkey).
4. Press 'Options' (left softkey) , highlight 'Add new connection' and 'Select' (left softkey).
5. Highlight 'Profile Name' and enter 'giffgaff GPRS WAP'
6. Highlight 'Homepage URL' and enter 'http://giffgaff.com/mobile'.
7. Check that 'Proxy' is ticked (press Navi key to tick/untick).
8. Highlight 'IP Address' and enter '193.113.200.195'.
9. Highlight 'Port' and enter '8080'
10. Ignore 'Linger time' (this is preset at 90).
11. Check that 'DNS' is unticked (press Navi key to tick/untick).
12. Highlight 'Bearer' and select 'GPRS' by pressing the Navi key right or left.
13. Highlight 'Advanced settings' and select using center Navi key.
14. Highlight 'APN' and enter 'giffgaff.com'.
15. Highlight 'Login ID' and enter 'giffgaff'.
16. Highlight 'Password' and enter 'password'.
17. Press 'Save' twice (left softkey).
18. Highlight 'giffgaff GPRS WAP' and press 'Options' (left softkey)
19. Highlight 'Activate' and 'Select' (left softkey).
20. Press 'Back' (right softkey) 3 times to return to the main screen.
Just installing polycom 501 phones with nextiva
Ohh this mean, you did not register this extension on your phone system. Create this extension on your phone system. Be sure that password given on Phonesystem is also configured on phone too.
2answers
Dead Polycom 501
u have the cable plugged in backwards
check it
Top Polycom Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
