20 Most Recent AT&T Sony Ericsson W580i Cell Phone - White Questions & Answers
adilwa - try resetting the phone.
guest - take the phone t a mobile service center and have the lcd replaced and also the charging port service or replaced.
AT&T Sony... | Answered on Oct 14, 2016
restart your phone and should be a menu that allow you to change to normal mode. Or put out your sim and open it with out sim close and do the same with the sim inside this time
AT&T Sony... | Answered on Mar 15, 2015
Do you want the unlock(NCK code)?I suggest you can approach Simpleunlocking.com and specify the country,locked network,IMEI of Sony Ericsson W850i.You can get the unlock code along with free instructions.
AT&T Sony... | Answered on Mar 24, 2014
That is a problem with your service.
AT&T Sony... | Answered on Mar 19, 2013
Settings - GPRS WAP
Sony Ericsson W580i GPRS WAP Pay & Go settings
Please note all steps must be completed to ensure the settings are correctly configured.
Please ensure that when entering 'O2' into the settings that the letter 'O' is selected not a zero.
The W580i has a central navigation button (Navi key) and two soft keys slightly above this.
1. Press 'Menu' (right softkey).
2. Highlight 'Settings' and press 'Select' (left softkey).
3. Scroll to the 'Connectivity' tab by pressing the Navi key to the right.
4. Scroll to 'Data communication' and press 'Select' (left softkey).
5. Highlight 'Data accounts' and press 'Select' (left softkey).
6. Highlight 'New account' and press 'Add' (left softkey).
7. On the 'Account type' screen, highlight 'PS data' and press 'Select' (left softkey).
8. On the 'Account Name' screen, enter 'O2 WAP GPRS', press 'Continue' (left softkey).
9. On the 'New PS data' screen, highlight 'APN' press 'Edit' (left softkey), enter 'payandgo.o2.co.uk' and press 'OK' (left softkey).
10. Highlight 'Username' press 'Edit' (left softkey), enter 'payandgo' and press 'OK' (left softkey).
11. Highlight 'Password' press 'Edit' (left softkey), enter 'password' and press 'OK' (left softkey).
12. Press 'Save' (right softkey).
13. Press the 'back' arrow key (key directly below left softkey) 2 times.
Activate GPRS settings:
14. Highlight 'Internet settings' and press 'Select' (left softkey).
15. Highlight 'Internet profiles' and press 'Select' (left softkey).
16. Highlight 'New profile' and press 'Add' (left softkey).
17. Highlight 'Name:' press 'Add' (left softkey), enter 'O2 WAP GPRS' and press 'OK' (left softkey).
18. Highlight 'Connect using' press 'Select' (left softkey), highlight 'O2 WAP GPRS' and press 'Select' (left softkey).
19. Press 'Save' (right softkey).
Change GPRS settings:
20. Highlight 'O2 WAP GPRS' and press 'More' (right softkey).
21. Highlight 'Settings' and press 'Select' (left softkey).
22. Ignore 'Connect using'
23. Highlight 'Use proxy:' press 'Select' (left softkey), highlight 'Yes' and 'Select' (left softkey).
24. Highlight 'Proxy address:' press 'Edit' (left softkey), enter '193.113.200.195' (to bring up the number press the number until it appears. Add the dots with the '1' key) and 'OK' (left softkey).
25. Highlight 'Port number:' press 'Edit' (left softkey), enter '8080' and press 'OK' (left softkey).
26. Highlight 'Username' press 'Edit' (left softkey), enter 'payandgo' and press OK (left softkey).
27. Highlight 'Password' press 'Edit' (left softkey), enter 'password' and press OK (left softkey).
28. Press 'Save' (right softkey).
Change Homepage:
29. Highlight 'O2 WAP GPRS' and press 'More' (right softkey).
30. Highlight 'Advanced' and press 'Select' (left softkey).
31. Highlight 'Change homepage' and press 'Select' (left softkey).
32. Highlight 'Name:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'O2 ACTIVE' and press 'OK' (left softkey).
33. Highlight 'Address:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'http://wap.o2.co.uk' and press 'OK' (left softkey).
34. Press 'Save' (right softkey).
35. Press the backward arrow key (key directly below left hand soft key).
36. Highlight 'O2 WAP GPRS' and press 'Select' (left softkey).
37. Press the 'back' button (to left of Navi key) 3 times to return to the standby screen.
AT&T Sony... | Answered on Feb 19, 2013
the pincode is on the simcard holder
AT&T Sony... | Answered on Dec 21, 2012
Plugin your USB Cable and using the Sony Ericksson app on your computer, update your firmware. If you update your firmware and it STILL doesn't work, then i am afraid its the phone.
AT&T Sony... | Answered on Oct 30, 2012
Hello
What you are experiencing is a flex problem
The flex is what connects the screen of the phone to the board of the phone.
what you are experiencing is common with all flip phones and slide phones, the more you flip and slide these type of phones,the flex gets weaker and that is what causes the whiteness
You should get a new flex for your phone
Goodluck
AT&T Sony... | Answered on Sep 09, 2012
sony erricson lock code is 0000 otherwise put new software into your phone.100% working guarantee.
AT&T Sony... | Answered on Jul 03, 2012
You can contact your network provider for your Sony Ericsson W580i codes. Or get the codes online at WickedUnlock.com
AT&T Sony... | Answered on Jun 30, 2012
Please check whether any other camera related application is running in the background. For that, do 'long-press' of menu button. Then exit that application then try relaunching the normal camera.
If it's not the matter, your firmware might have been corrupted. Try re-installing it, either using SonyEricsson PC suite or at an authorised service center.
Regards
Vineeth K.
AT&T Sony... | Answered on Jan 09, 2012
memory cord msdc setting
AT&T Sony... | Answered on Sep 02, 2011
Your messages are saved in your phone memory & not on the memory card. You need to install PC suite now companion on your PC which is available on sony ericsson website & usb cable. Forget about the CD. The needed software are there on the website.
AT&T Sony... | Answered on Aug 09, 2011
download an antivirus software in ur phone and scan ur phone
AT&T Sony... | Answered on Jun 20, 2011
1. its either the battery or the charger.
2. you could visit the dealer to check your phone`s battery is ok, and /or try another charger.
Hope i`ve been a help.
AT&T Sony... | Answered on May 10, 2011
You get the unlocking service from http://www.theunlockarena.com/sony-ericsson-w580i/rs13wp9/ .Here i found the valid codes.Through this you can unlock your mobile easily.
AT&T Sony... | Answered on May 05, 2011
A request for a PUK code ("Personal Unlocking Key") will appear on your phone if your SIM card PIN code is entered 3 consecutive times incorrectly.
Your SIM card will then become "PUKed" or Blocked. This is a security measure to protect your service.
You need to call the Customer Service department of your cell phone provider and they will give you the PUK code which will unblock your SIM card.
AT&T Sony... | Answered on Mar 15, 2011
To get the security code to unlock the cell phone from the current cell phone provider so you can use it with a different phone provider, Please click on this link and follow my instructions :-
http://www.fixya.com/support/r4049238-unlock_cell_phone
If your phone provider does not help you then this WEB site it provides security codes for a small price.
http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw
Try this WEB site also - Unlock Free
http://www.unlock-free.com
AT&T Sony... | Answered on Feb 14, 2011
Hello thanks for using fixya
You can easily reset your
Put the memory card out(if it have), Now Go to Menu >> Settings > Reset > Reset All. If it ask the default code then it is 0000.
That will reset your phone to factory settings
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
AT&T Sony... | Answered on Feb 01, 2011
AT&T Sony Ericsson W580i Cell Phone - White Logo
169 questions posted
Top AT&T Cell Phones Experts
Vincent G
Vincent G
Trimesh
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
AT&T Cell Phones
  • AT&T Cell Phones
Most Popular Question
phone says puk blocked
  • Cell Phones
