Are you on well water? If so you may have dissolved iron in the well water, it enters your house as clear water iron and then once areated in the tub it turns yellow as the iron oxidizes. Another sure sign of this is if the water in your toilet yellows after sitting in the bowel with no use after a few days. Solution: have a reputable local water treatment company come test your water, test for disolved iron, total hardness, and pH. If the disolved iron is 5ppm or less then a water softener will fix the problem. Make sure they add a turbulator to the softener and use iron fighter salt or mix iron-out into the salt tank.
