F1 means u have a leak where pump and control module is. that is located under sump.the water has activated a flood switch near drain pump. need to find leak to fix problem. make sure power is off to unit b4 looking.please reply to how u go. good luck
F1 means that your dishwashers have flooded. You can
download the video in the link below to see how to get rid of the error and fix your dish drawer for numerous other problems.
Appliance Repair Video
Order Fisher Paykel Rotor in this link if needed
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
The fill valve has failed open.
The flood switch is faulty.
Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
