Lenovo  Keyboard Logo
Posted on Mar 13, 2010
PC does not detects my Omega keyboard anymore
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Mar 13, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
58462
Points
10
First question I'd want to resolve is whether the keyboard is bad, or you have a system problem. Plug keyboard into another PC and see if it works.
If it does, try uninstalling the keyboard using device manager, rebooting, and plugging keyboard back in.
Omega watch setting minute hand
There is a way to put the crown back in by pushing a certain bar in the watch, but you need to take it to a pro because watch insides are super delicate. I've changed batteries, removed links etcc for 16 years and I wouldn't touch this procedure
My keyboard just quit working. What can I do to fix it.
Your only option on a notebook keyboard is to find a replacement on eBay. Google for diagrams and replace it yourself. Take digital pictures as you go so you know how to put it back together.
Here what you need to know about standard keyboards:
The older, round keyboard plugs must be plugged in when the computer starts up or they will not be detected. Make sure none of the plug pins are bent and it is connected to the correct port then restart the computer.
Keyboards with USB plugs can be plugged in and unplugged while the computer is running. It does take a few moments for the computer to detect the change.
If it still doesn't work don't waste anymore time with it. Replacements start a $14 with shipping. (www.newegg.com)
If this helps please vote for my solution.
8helpful
Need driver for keyboard omega sagitta OK 203
hi, everybody this is Jeff
I get my Omega usb keyboard that doesn't work with xp professional i need the software driver for it. thank you
My dell dimension xps 400 does not detect mouseand keyboard
Hi, these instructions will help you, and "everything that you do for the Keyboard; apply the same instruction to the Mouse." First, click on the "Start" button, in the ["Start Search Window], Type: keyboard; the "Keyboard" Properties window will open. You can (Test) to see exactly how your keyboard is responding. If you are still having the same problem, (check, the Keyboard Status). "Update the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; "Uninstall the Keyboard. To "Uninstall the "Keyboard," do the following: Shut-down (turn- off completely); disconnect all the Keyboard Devices that are connected to the Computer. Next, turn-on the Computer, and go back to the "Keyboard Properties," next, click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the Computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the Computer. "You will repeat exactly what you did from the start, this will "Re-install the Keyboard. "Restart the Computer again after all changes have been made; this will ensure the changes take effect properly. "Rating the solution will let me know if it worked; or you may need further assistance, thanks."
Hi, the CS62U is connected with an HP8750 (win2000) and a MSI WIND NETTOP 120 (win XP home). It works perfectly with the HP desktop but the mouse is not responding anymore.
Try this:
1. Disconnect your HP computer, so that only the MSI Wind is connected.
2. On the keyboard, hit [Numlock]+[-] then press [A] (this will auto-search for the computer that's connected, and connect both keyboard and mouse to that port).
Give XP a minute to detect new hardware. If XP does not detect the mouse, try plugging the mouse into a port directly on your netbook. If XP still does not detect the mouse, it's XP that's not detecting your mouse properly, not the kvm switch. :) If it does detect it, you should be able to then plug it back into your kvm switch and it should work at that point.
Note: if you get stuck with lights flashing on your keyboard, just hit [Esc] on the keyboard. That will reset the KVM switch.
Hope this helps!
2answers
The sk8110 keyboard is not being recognized by my
well u need to scan hardwares or bluetooth device to have it detected and then install the driver..it should work fine
As soon as I plug in/switch on my midi keyboard, the USB LED flashes
dear sir,
your problem is very simple. please check the didi key board seriel pin.some time the seriel pin is broken. your goole problem is network problem.please check the network connectivity. otherwise operating system problem.sometimes while your installing the operating system some files missing. so first check your computer network and serial port.
thanks & records
sakthivel
Keyboard not working
Hi abcd_21;
Is that a usb keyboard or a PS2 keyboard? if its a PS2
kindly Do these steps below:
1. remove keyboard PS2 from PC
2. restart PC, and observe if you see the error "no keyboard detected"
3. turn the pc off
4. attach the PS2 kayboard then Turn ON.
if its a USB:
1. remove usb
2. restart pc
3. plug the usb in when the pc has completely booted up.
4. wait for the found new hardware icon to detect your usb
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
