Select your video file and click “Open.” The video and SRT file should begin playing automatically. If the subtitle does not display, click “Pause,” then right-click the video screen. On the right-click menu, select “Subtitles” and click “Enable.”
Leawo Blu-ray player and VLC player are both good choice for you to add subtitle to your movies. If you are looking for solution on how to add subtitle and fix VLC subtitle delay issue, you can have a check at this article. Hope it helps. https://www.leawo.org/tutorial/tips-fix-vlc-subtitle-delay-1410.html?fixya=1410
You can try Leawo Blu-ray Player which is very easy to use to play subtitles on the movie playback.
Step 1: Run Leawo Blu-ray Player and Choose Video
Open Leawo Blu-ray Player on your computer and then click "Open File" button in the interface. The chosen video will be loaded to the software right away.
Step 2: Call Out Subtitles Menu
Right-click anywhere on the interface and then choose "Subtitles" option from the pop-up panel.
Step 3: Enable Subtitles
After you enter "Subtitles-Settings" page and you need to check the option of "Enable subtitles" to continue.
Step 4: Select Subtitle File
Choose "Browse for subtitles", and then you can browse the subtitle file you want to add from your computer local folder.
Try playing your movies with VLC Media Player, which can be found here:
http://www.videolan.org/vlc/
It's 100% free and can play all types of codecs.
You can just drag and drop your subtitles over the movie once it's started.
What is the player you are using now?
ON WHAT, TV or PC or? dedicated player, is this DVD or BLu-ray disk....
1; first of all the DVD/BR or MP4 or MKV (and others) all must have SUBS there in the first place and in your language.
2: we have not one clue by you what Player you use at all. (netflix on TV or , windows player on a pC?)
yes if a PC run VLC> free
yes, ? VLC, then right click bottom bar of VLC, and pick subtitles. and sub tracks, if seen there , use them if not there then THEY ARE NOT THERE.
what is a movie, to you???? we do not know,
ever.
unless Stated
if PLAYING,on a TV say , >>TV.
if streaming movies of the web say Streaming. (vast players exit, like netflix.com)
DVd Played that are older than 2014 , did not need to have subs. or at their option. law of 2014 changed that. in uSA are you USA< not told.
no PC told , or TV< no OS< no player told no country told so... answers are hard.
for sure what media it is exactly, not told.
also you can add subs, this I know well. done many.
