This is more likely an issue with you video card than your monitor, do all the monitors you have tested operate at the same resolution and refresh rate? It sounds like the LG monitor is running at a higher resolution and refresh rate which is causing addition load to be placed on your video card causing it to crash
SOURCE: Computer monitor screen stays black
i have a proplem in my monitor, always it appears as lots of screeching thin line whenever i on my PC, is there any solution to solve this problem? please help me.
SOURCE: cant get stand out of monitor
Hi Russ,
Please find the solution below )):
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
SOURCE: Flatron L1919S (Black) LCD Monitor: Is my LCD monitor, LG Flatron L1918S, good enough ...
You should google this. After looking myself i have seen that it should play HD movies without a problem.
