Not a solution... seems like it is blocked, mine freeflows at least a little water when you turn on the hose (engin off)... Did it get a big slug of dirt from the hose of fawcett? .... puzzzling....
Well, I am not setup for live chat... think they offer that for the "Experts" but you end up paying for that I believe..
Getting water through part of it.... there are not that many parts to the pumps... does it buld up pressure in the hose? The outlet you plug the hose into usually has a check valve like an air hose to keep the water from going out it if the hose is removed....
Inlet-pump-pressure relief-outlet-hose-spray handle valve. all thier is to them....
Does the engine sound like it is turning the pump over?
I thought this would be "Live Chat ?" In response to your response...I opened up a few places to see if water from the inlet flowed out and it did in some of the places but not up thru the outlet pipe to the pressure hose. ?
