Scan Pc for virus and spywares, read my tips on face book on how to optmized your pc. .........metropcstech
Run System In Safe Mode:
To identify the root cause of theproblem, first of all restart your system, press and hold F8 key. Do thefollowing once you are on the desktop.
1. Right click on Computer.
2. Select Manage.
3. Click on Event Viewer in computer management.
4. Double click on Application.
5. Check for the errors.
6. Similarly double click on System and check for the errors.
7. Search for the solution to this problem.
Now you are able to easily diagnosewhy Windows laptop starts up very slow.
b>
Limit your Startup list:
A long list of programs in startupcan adversely affect the performance of your PC. There are some programsrunning in the background without knowledge of user that causes Windows laptopto start slower. To solve the problem, follow the steps given below.
1. Click on Start button.
2. Type "msconfig" in search option.
3. Double click on the file.
4. Click on Startup.
5. Uncheck all unwanted programs.
6. Close system configuration utility.
7. You are done.
b>
Uninstall unwanted program:
Sometimes Windows laptop starts upvery slow due to unwanted programs hogging your memory. To fix this problem,below are some steps.
1. Click on Start button on thetaskbar.
2. Go to Control Panel.
3. Double click on Add or Remove Programs.
4. In the list of programs, select the program that you no longer needed.
5. Click on Remove button.
6. Repeat step 4 for all unwanted programs.
7. You are done.
b>
Scan System for Viruses:
Windows laptop may start slower due to any virus onyour computer. To solve this problem you should scan your system with somepowerful antivirus program.
b>
Run Disk Clean Up:
Running disk clean up utility isalso helpful to resolve slow Windows start up. To run disk clean up utility,here are the steps given:
2. Go to All Programs.
3. Click on Accessories.
4. Now click on System tools.
5. Click on Disk clean up.
b>
Defrag hard disk:
2. Go to Command Prompt.
3. Type "chkdsk" and press Enter.
b>
Defrag Registry:
You mayuse some safe program such as McAfee secured RegInOut to fix registry relatedissues.
Is there much HDD space left? And have you run a disk check and defrag?? Also could be driver based... Please clarify if you have latest drivers. :)
