20 Most Recent
Dell Inspiron N4010 Notebook Questions & Answers
How do I highlight words to copy and paste them
Well, to highlight words you have some choices. Using the mouse is likely the easiest. If you double-click any word it will automatically highlight. If you triple-click it will highlight the entire sentence.
Alternatively, you can drag to highlight. Consider the following:
The cat climbs up the tree.
If you place the cursor (mouse) at the first capital T and then click and drag to the . at the end it will highlight. You can get specific this way.
The following is dependent on what application you are using. If you are using a Word Processor (like MS Word, Libre Writer, or Notepad) you can actually highlight with your arrow keys and shift.
If you take the previous example and were writing in Word, you could use your arrow keys to go to the "cat" portion and then hold down "Shift" - while holding down shift, use your arrow keys to begin highlighting letter by letter.
Give it a shot!
You can then "copy" by using the keyboard shortcut "Ctrl + C" or by "right-clicking" and selecting copy. Lastly, you can press the key on your keyboard that looks like a menu. It is between the ALT and CTRL keys on the right hand side. That is the "Context Menu" button which is the same as "right-clicking".
To paste, the options are similar. You have to click on where you want to paste and then use one of the following:
"Ctrl + V" to paste
"Shift + Insert" to paste
or "right-click" then paste (Or press that context menu key on your keyboard and select paste with your mouse.)
Hope that helps!
Fusible dell n4010 ubicacion
Remueve la bateria y trata utilizando otro Power Supply. Si aun asi no enciende verifica que no este roto el conector de poder que est? en la laptop. Si est? roto es posible que si tenga un corto y requiera una labor m?s extensa y profesional.
F1 key - accidently hit the duplicate, how do I undo this?
Hello!
You can toggle these settings by using he Fn key in conjunction with F1. If using Windows 7, you can try using the Windows Key + P to bring up the projector options, duplicate being one of them. Alternatively, you can press Windows Key + D (shows desktop) and then right click anywhere there is NOT an icon and select Screen Resolution. Under "Multiple Displays" you can select the option you are looking for. Hope that helps!
My computer is dell inspiron n4010 win7 32bit but
You can connect to internet and follow the procedure
go to --- my computer > right click on it > go to properties > device manager > click on the computer name shown in device manager screen >click scan for hardware changes > then the driver will install automatically .
Touchpad zoom
You can download the user manual here: http://www.dell.com/support/Manuals/us/en/19/product/inspiron-14r. That should show you what you want.
Error diagnostics drive 0142
when you say window will not open we does it crash. this mostly is just and driver thing. boot for your windows dish and do startup repair to see if it can fix it.
Speakers plug headphone
first of all check your computer by using it with any other headphones
if the problem persists then you fix your computer otherwise your speakers jack is not working properly
