20 Most Recent Dell Inspiron 1720 Notebook Questions & Answers
5answers
My dell laptop keys 1QAZ KEYS ARE NOT WORKING
if a row is not working, in this case at an angle, it usually means either the keyboard is going bad, or the cable is not in right. Often unplugging and replugging the keyboard into the MB will fix a missing row.
4/30/2022 12:40:36 PM • Dell Inspiron... • Answered on Apr 30, 2022
4answers
I am running windows 7 and I would like to know how to install an old version of printmaster silver 10 on windows 7
Printmaster 10 may not work with Windows 7. Just uninstall Printmaster 2012 then install Printermaster 10 using the installation CD.I recommend you go to the Printmaster support site and ask them if version 10 will work with Windows 7 so you do not have to uninstall 2012 version if version 10 will not work with Windows 7.
5/27/2016 2:58:48 AM • Dell Inspiron... • Answered on May 27, 2016
Why can the battery, which has been in use for 12 months, no longer be detected?
Could have a dead cell in it
8/29/2014 2:19:13 PM • Dell Inspiron... • Answered on Aug 29, 2014
ISATAP#17 not running
you have not described you problem in full detail but even i try to solve it. when laptop is in off condition you have to press R + Turn ON button which makes reset (not restore) your C MOS memory so whatever settings has been changed are automatically resets and your laptop will turns ON so just do it. If further problem occurs then immediately call DELL onsite service.thank you for giving me this opportunity to solve you problem.
1/22/2012 10:12:30 AM • Dell Inspiron... • Answered on Jan 22, 2012
2answers
Wifes brand new dell inspiron suddenly running
Scan Pc for virus and spywares, read my tips on face book on how to optmized your pc. .........metropcstech
7/19/2011 4:43:32 AM • Dell Inspiron... • Answered on Jul 19, 2011
I have upgraded my dell
What do you mean by "Back Light"? There should be drivers for everything at your manufacturer's website.
6/5/2011 7:23:14 PM • Dell Inspiron... • Answered on Jun 05, 2011
My dell inspiron 1720 locks up frequently - this
Try running these scans in Safe Mode.
Keep pressing F8 on startup, and choose 'Safe Mode' from the list that appears.
If you still find it locking up during scans, you may have a hardware problem that needs fixing.
Regards.
4/27/2011 10:19:46 AM • Dell Inspiron... • Answered on Apr 27, 2011
Iku o;
Hi there.
How can we help you?
3/22/2011 3:58:45 PM • Dell Inspiron... • Answered on Mar 22, 2011
Well is the acer crystal
This is just a camera like any other one. You can use it to take a picture, record a video or do a web chat with video. To do any but the last one you do not need to be online.
3/17/2011 1:08:41 AM • Dell Inspiron... • Answered on Mar 17, 2011
My Dell Inspiron 1720 tries to boot up.. then it
during the boot up process for a short time you will see press a certain key to enter set up press that key to enter BIOS scroll to PnP/PCI configurations the default is disabled select enabled to reset configuration if you have installed a new add on and it has caused a serious conflict that the operating system can not boot
another one of the possibile reaons is
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart do not do anything while the chkdsk utility is in progress any input will damage your computer hope this helps
2/26/2011 11:26:47 PM • Dell Inspiron... • Answered on Feb 26, 2011
My dell battery charger less than a week
The problem might be with your battery and not your charger. The lithium batteries that are used on laptops have a definite 3 year lifespan to them. Once that time passes the battery will no longer charge to 100%, and it will discharge quicker and quicker. Dell has a built in battery minder program installed on their hardware. If you left click on the Quickset icon in your Taskbar, a window with 3 tabs will open up. The last tab accross the top is for battery health. You can click on this tab to see if there are any warnings for your battery. If it is close to the end of its lifespan you will see a message similar to "Your battery is able to charge normally. However it is reaching the end of it's usable life. You can experience a longer operating time with a new battery. You might want to consider purchasing a new battery now." Once your battery does reach its end, you will get a red warning balloon stating the battery is now at the end of it's cycle and needs to be replaced.
If you do not see any of these messages then the fault probably lies with your charger. The only way you could test this is to try another charging of the same model. If you do not own an extra one then you will probably have to take your system into the local repair shop to have them test it out.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
2/18/2011 3:10:25 PM • Dell Inspiron... • Answered on Feb 18, 2011
I took my dell inspiron
take it back to the shop, it's probably not been reconnected properly.
2/11/2011 9:55:05 AM • Dell Inspiron... • Answered on Feb 11, 2011
This is similar to my
load dell diagnostics and check your hard drive, one of the options when the dell logo is on the screen.
2/11/2011 9:54:12 AM • Dell Inspiron... • Answered on Feb 11, 2011
My laptop fails to start...
Your operating system is damaged, First try loading default value in your bios menu via in the exit tab, then save and exit which could be clocking error registration. If that doesn't work, I would assume that the operating system is currupted and you need to repair your operating system with the recovery/driver cd that came with your system. Load that into your drive, and change the boot option to dv/cd as boot priority and follow direction from there on. Should be a option to repair windows and a option to reformat and clean install. You want to repair first, to see if the promblem is solved. Please save or copy any important data before formating your drive. If you should have any question please feel free to ask.
1/29/2011 7:49:44 PM • Dell Inspiron... • Answered on Jan 29, 2011
Dell Inspiron 1720 Notebook Logo
73 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
dell inspirion 1720 laptop unfortrunely
  • Computers & Internet
