Avaya Eurostyle 18D Corded Phone Logo
Posted on Feb 25, 2010
HOW TO SET INTERCOM - Avaya Eurostyle 18D Corded Phone
A
Anonymous
What do you mean, "Set Intercom"? Program someones intercom on your button?
Feature00
press the button you want to program
press the LEFT intercom button and the 2 digit extension number
feature00
2answers
Intercom uniden D1688
After reading the manual over and over with no success, I got the hint to successfully do an intercom call by reading a post from a website.. The manual says to press the Intercom buttom. Then select the phone you wish to intercom with (or All phones) - do this by using the up-down button. The step left out of the manual is: THEN press the MENU key. It works perfectly!!
WHEN I CAN AN EXTENSION A GET A MESSAGE THE THAT LINE IS NOT IN SERVICE. HOW CAN I FIX THIS?
The not in service message is given when there is no telephone attached to the intercom number your trying to call. I'd re-check the intercom number your calling, this can be done by using the button inquiry feature on the set your calling. At the set your calling, press feature *0, then press the intercom button on the lower right hand side of the set. The screen will display the intercom number of the set.
Is there a way to intercom directly onto the speaker ???
you should have 2 intercom buttons on your set, an SA ring and an SA voice. The SA voice (or voice intercom) should be the second from the bottom.
Security code
intercom #673 to lock
intercom #674 to unlock
to overide the code intercom #674 '0000' (4 times zero)
3helpful
Set time and date toshiba dkt2010-s
DK Programming
From Reception phone only
--(time set)DK- intercom #652 HH mm SECs redial
--(date Change)- intercom #651 yy mm dd redial
CTX Programming
--(time set)ctx-intercom #652 HH MM SEcs #
--(date change)-intercom #651 YY MM DD #
To set time and date on toshiba
What Toshiba system do you have?
CTX Programming
DK Programming
PLEASE, PLEASE try and help me...I can't tell you how much this would be appreciated. I have a Panasonic KTS4100 4 line phone (2 corded phones in our office, and one cordless). I have NO IDEA how to use...
Just in case you missed the manual:
http://www.centralcomms.co.nz/pdf/KX-T2375-brosh.pdf
There are 2 conditions you need to be aware of
1 No DSL on the line
2. Set the intercom extension of the second phone
By default, both have been assigned ext 11. The intercom uses the same frequencies as a DSL line to transmit, so that could be the noise you are hearing.
Page 23 tells you how to set the intercom extension, and the DSL warning is almost at the bottom of every page from 18-22.
Carl
Lost programing
From extension 10.
you have to set the ringing.
feat 00
left intercom twice
right intercom once
enter ext number
touch the lines util they display how you want them to ring
feat 00 when done.
To set the feature to p/u a ringing call
feat 00
left intercom twice
right intercom once.
press: ** (then press lines in order 1, 2, 3, 4, etc)
then press ** again.
feature 00
repeat both for all extensions.
Top Avaya Lands Phones Experts
NOEL
NOEL
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
