20 Most Recent
RCA 25414RE3 Corded Phone Questions & Answers
No dail tone
Check the cor and cos setting of the phone It shold have the permissions to call outside
Intercom
Each of the six phones must have line 1 connected to the same "subscriber loop" (the same phone number). Assuming this is the case, and that you have not assigned any numbers to the the top six speed-dial buttons, each station will have agreed to be assigned a station number.
From any station, pressing the speed-dial button for another station's station number will page that station.
Now, how to properly initiate an intercom conversation differs between announcing to another station that a call is on hold, or a "cold call".
How do I stop the red message light from blinking after I have received my messages
~*~*~ SOLVED SOLVED SOLVED! ~*~*~ After talking to both ATT and RCA with no success...I figured it out. ~*~*~ Plug your phone line into the "DATA PORT" on the back of the unit. Slide the "DATA PORT" switch to whichever line is showing it has a message. Press the corresponding Line# button on the front of the phone. (you should hear the dial tone) Dial your voice mail number. Let it answer, (enter your passcode if needed), then hang up! - That's it! example: MSG Waiting:L2 - I plugged the phone line into the Data Port and moved the data port switch to "2". I pressed LINE 2 on the front of the phone, dialed my voice mail number, it answered, I put in my passcode. (It said that I did not have any new voice mails), then hung up! That's it! Message Indicator light off!!! Repeat for each line that shows a (false) message waiting. ~~~Don't forget to move your phone line back into it's correct port on the back of your phone.~~~
Rca tech support: message light blinking
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
New Message Light won't stop flashing
Don't know about other models, but I just called RCA small business
phone support (800-511-3180) to find out how to clear the message light
indicator on my 25210 2-line cordless phone when it continues to blink
but there is no message.
All you have to do is hold down the delete button for a few seconds and
it will clear. Hope this helps someone else from going batty!
Line 1 and two not splitting
You can find the combiner at Radio Shack Model: T07843 ' Catalog #: 55034722. It may only be online not in the stores.
Message Indictator
hi
its hard to understand...
the phone is connected to line 4 or not?
if so and line 4 is dedicated to fax line
then the fax tone is the cause of your confusion
fax tone is different from a regular tone phone
if the phone isnt connected to line 4 and only to all 3 ordinary lines - then the phone is getting a over volage from them
and activates the light & messege alert
my advice
let it be
you will start playing with it something else will go worng...
good day
Message Light
The only thing you can do is unplug the unit from the wall and from the phone line. wait over night and see if this resets the unit. if it does not, I,m afraid there is a circuit problem in the phone and most likely will not be worth repairing, but try to hard reset like I said first. good luck
