<b><a href="http://www.recoverwindowspassword.com/windows-7-forgot-password.htm">Forgot Windows 7 password</a></b>?
Locked out of your computer? Don't want to reinstall your computer as
there are some vital data on it, like precious images and your school
essay? Then what should you do?<br />
<br />Windows 7 allows PC users to enable fingerprint logon, but most PC
users are used to set a password in Windows 7. It is much easier for you
to create a Windows 7 password consisting of symbols and numbers than
to create fingerprint logon. But the only disadvantage is that you have
to remember the password. Otherwise, it will be troublesome if you are
locked out of computer when you forgot Windows 7 password.<br />
<br />Although Windows enables you to create a password reset disk in
Windows 7, it seems to have little effect. Many PC users don't know how
to create a Windows 7 password reset disk. And some don't remember to
create the password reset disk until they forgot Windows 7 password.
Everyday there are many questions about how to <b><a href="http://www.recoverwindowspassword.com/reset-windows-7-password.html">reset Windows 7 password</a></b> online. Here I recommend you to try Windows Password Breaker when you forgot password on Windows 7.<br />
<br />Windows Password Breaker is a helpful Windows password recovery tool for you to reset password when you <b><a href="http://www.recoverwindowspassword.com/">forgot Windows password</a></b>,
including Windows administrator password or user passwords. It supports
to reset passwords of all Windows versions, like Windows 7, Vista, XP,
2008, 2003 and 2000, etc. With this password recovery, you easily remove
lost Windows password by burning a bootable CD/DVD or USB flash drive.<br />
<br />Steps to remove password with a bootable CD/DVD when you lost or <b><a href="http://www.recoverwindowspassword.com/windows-7-forgot-password.htm">forgot Windows 7 password</a></b> as follow:<br />
<br />1. Download Windows Password Breaker Standard in any computer.<br />
<br />2. Run the program and burn a bootable CD/DVD or USB flash drive.<br />
<br />3. Set your computer boot from CD/DVD or USB.<br />
<br />4. Reset lost Windows password.<br />
<br />Now you successfully remove windows password with Windows Password
Recovery Standard. You can log on your computer without password. No
need to worry about anything if you forgot Windows 7 password. You can
also use a USB flash drive like iPod to remove forgotten Windows 7
password based on the above steps.<br />
Locked Password where? Bios Password? Hard Drive Password? Windows User Account (userid) Password? And which operating system?
If it's the Bios Password, then you will need to remove the CMOS Battery and let the computer sit for a couple of hours. Then put the battery back in and try rebooting. You'll have to go back into the BIOS or Setup to put the correct date and time in but the password should be gone from memory.
If it's the Hard Drive Password, you're kinda out of luck. Hard drives are locked 99% of the time when the computer is stolen. The original owner either locked it while he had possession of it or he could have locked it remotely when it was stolen to keep thieves from getting to sensitive data. The only way around it is to have the original put the password in, or Purchase a new hard drive to put in the computer, reload the operating system, reload the drivers and reload application programs.
If it's the Windows Password for User Account turn off the computer, then turn it on and immediately start hitting the F8 key until you see the SAFE MODE Option. Take the Safe Mode option to boot the computer. When it comes to the login screen it will show you the Administrator account and the Account for which you forgot or don't know the password. Log into the Administrator account (hopefully you didn't password protect it and forgot it). When windows desktop comes up click Start/Control Panel/User Accounts. When the User Accounts window opens up click on the User Account for which you forgot the password then select Remove Password. Reboot the machine
Turn on the TV, put it on whatever channel you have when you watch a dvd....
While the unit's in STOP mode, hold down the unit's l<< (skip button) and the STILL\PAUSE button down simultaneously and then the POWER button for longer than 3 seconds (until "Initialized" disappears from the TV monitor) The lock will be released and all initial settings will return to the Factory default values.
good luck to you....let me know if this worked!!!! mtg
If you forgot windows login password, you could enter into safe mode (F8 when booting up) to reset windows password while you forgot user account password, but if you forgot administrator password, there is no way to change it, you should use programs to recover admin password. Yesterday evening, I forgot my Windows administrator password. In the end, I used Windows Password Seeker to reset my Windows password successfully. It's worth a try.
If you locked your iPod and forgot the password you can unlock it using iTunes. Simply connect the iPod to the primary computer you use for adding music to the player, start the iTunes software and synch the player. The iPod will be unlocked and you can then use it normally.
