Computers & Internet Logo
Posted on Feb 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My livebox set up cd has gone missing - Computers & Internet
A Miller
Level 3:
  • Master 8,404 Answers
  • Posted on Feb 20, 2010
A Miller
Master
Level 3:
Answers
8404
Questions
Helped
2053350
Points
24677
No Internet connexion between livebox 2zte and dap 1320 .
First connect to the Livebox (without the range extender) to see if you can access the internet. If you can get on the net there open your browser and type http://dlinkap.local in the address line, and set-up the d-link. the most common problem is the password on the router (the livebox).
For instructions for the D-Link go here;
http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201320/Manual/DAP_1320_Manual_EU.pdf
For instructions for the livebox (translated into english);
http://translate.google.com/translate?hl=en&sl=fr&u=http://assistance.orange.fr/installer-la-livebox-2-zte-4665.php&prev=/search%3Fq%3Dlivebox%2B2zte%26rlz%3D1C1ASUT_enUS567US567%26es_sm%3D93
1helpful
Canot connect Ipad 2 to orange livebox.
You must connect via wifi to your livebox without problems. You may only go to Ipad settings and select the livebox wifi. I do not understand the problem.
Is it compatible with livebox2 it does not respond with livebox2
Yes it is compatible with any livebox as long you have a wifi connection...You just nees to reset your phone and security key and reset your livebox and type in the security key of your livebox its always found under the livebox.
2helpful
Wireless connection using livebox and belkin usb adaptor
You most likely need to reconfigure the livebox settings. The Livebox lost the settings because it was unplugged too long. Most router settings can be accessed by typing in 192.168.1.1 or 192.168.0.1 in the URL address bar of any web browser. From there, make sure that all other switches and devices on the network are on the same network. Meaning if your Livebox default gateway is 192.168.1.1 make that the switch that other devices are connecting to the network through are assigned the IP address 192.168.1.x where x is any number other than 1. I hope this help, I know its not comprehensive enough but once I'm a 'Guide' you will be able to chat with. Then we can have conversation via IM Chat. This is my area of expertise.
I cant get my I Pod Touch to connect to my Livebox. I have put in every password I can think of including the 26 digit Livebox one - any ideas. It is so frustrating to have been given my I Pod as a...
You need to out the Livebox into pairing mode to allow the iPod Touch to connect.
Press the button marked '1' on the back of the Livebox. This will start the wireless LED flashing and puts the Livebox into 'Pairing' mode.
Use the WEP key that is printed on the label on the bottom of the Livebox.
NOTE: There is a limit to the number of devices you can connect.(6)
Girlfriend has new aspire one we are trying to connect to home wireless network on orange with a live box acer was set up to someone else's network we can get it to see livebox on acer but will not connect...
You need too set up a totally new network.goto networks,click setup new network and follow the instructions. You will need the password for the livebox and more than likely need to call your network provider. If you have a desktop pc in the building its probably easier to set up a Home network
2answers
Belkin wireless adapter g usb
WPA is safer as all in all it's a lot harder to crack due to being a lot more characters in the passkey. The easiest thing to do would be explain how i have mine set up. And you could compare the 2.. As i have XP Desktop & Vista aswell. So your Laptop connects ok now but is still an unsecure network.. On your Dektop. When you try to connect. Are you entering the 26 character key on the bottom of the livebox?
The main thing to realise with the Livebox is everything is reversible.. And to not worry about changing something..
So let's get this started, When you open up the " Connect To A Network " you can see your Livebox-XXXX. Next to that does it say "Unsecured Connection"? If this is the case then your Livebox is still not properly configured.. What i would recommend doing is starting a fresh with the Livebox, and i explain how to set it all up from Default. icon_smile.gif
IF you don't remember your internet login details then go to "Configuration.adsl" and click My Services then Internet. Your info will be in there. Hopefully you remember your password.. icon_smile.gif
If you don't know how to do a reset of your liveox. Press and hold the "1" button on the back of your livebox. Unplug it from the mains whilst still holding the "1" for 10 seconds. Then plug it back in. [ still holding the "1" ] The lights will flash a bit and after a minute or two it will go back to normal.
Go back to "configuration.adsl"
Username: Admin
Password: Password
If i start from the top section and work down it should make it easier to follow:
My Services>Internet>Connection Parameters Filled In..
Phone Over ADSL> Nothing needs changing
Digital TV> Nothing Needs Changing.
Liveprinter> Nothing Needs Changing.
Submit
Security> Associated Devices> Will Be Empty
Firewall> Medium
Wireless Connection> Channel Number> 11
Security Key(WPA-TKIP)> Same As What's On Bottom Of Livebox.
Enable Wireless Lan> Ticked.
Submit
Configuration> Update> v5.10.7-uk
Administrator> Change the password while you're there..
Submit
Advanced> Wireless> Pairing Time> 10 minutes should be fine.
Your Livebox name can be left as it is.
WPA Security Only
Wi-Fi Easy Pairing.. Might aswell leave it on..
Submit
Now if we set up your laptop first.
Go into Connect To A Network. Your Livebox should be there. It also SHOULD say Secured Network. If there is a Red Cross then you will need to do what i suggested yesterday on my previous post.
Go back to connect.. Enter the 26 char. passkey with caps lock on.. And you should be connected no problem.
Now for the Desktop.
when you log on.. In the taskbar in the bottom right should be something to do with wireless networks. Double click this.. If it mentions something about using the software that came with the device.. Then use the software.. If not then windowsXP will show your network. Double click it.. Enter the same 26 character code.. And you SHOULD be connected.
Let me know if that works.. Sorry for the really long post, but detail is something i do quite well... icon_smile.gif
2answers
Connecting ipod touch
Press pairing 1 button on the back of the livebox and then type in security code make sure that you type in each character in capital letters as the code it is case sensitive (don't set caps lock) for each character use the shift key - You will now be connected to the livebox.
Orange Livebox and NIC
Sounds like an internal problem with the Orange Livebox NIC controller.
If you have an other router Lynksys/belkin you could try it would isolate the problem definitively
2answers
Connecting powerline ethernet adapters through orange livebox
Try to eliminate the problem into smaller parts. Try networking the two via the same power outlet via a multiple power board first in the same room. I don't have much experience with these powerline ethernet but i'm sure the configuration of these will be very similar as wireless router / access points and wireless adapter cards. However what I do know is that your power outlets need to be on the same "phase" of your electrical power system, so if you do this test I suggest (from one outlet board) you know the equipment works and your setup procedure works. then try seperating again and if it still doesnt work, check if your power outlets are wired on seperate phases (depends if your house has 3 phase wiring incoming to your home or not). Try another room or another outlet.
Grand Canyon Tech
Grand Canyon Tech
