I recently purchased a memorex usb 2.0 128mb flashdrive and not sure how to get it to work with HP desktop computer to transfer photos and other data files
Just try this one. try to insert your flashdrive to a usb port where it is compatible then a message will appear saying open folders to view files then you can now copy and paste a pictures or songs on the pc or on ur flashdrve.
You must need USB Flashdrive to update it. Please make sure that your USB Flashdrive is bootable. Here's the link on how to make USB Flashdrive bootable: http://www.makeuseof.com/answers/usb-drive-bootable/ After you make your USB FLashdrive bootable, copy that BIOS update folder in your USB flashdrive. Please also rename it in simple words so that you can easily access it using command prompt. And after that make your USB flashdrive as first boot priority. Then save and exit. When the USB flashdrive is now booting. Type this: cd (name of the BIOS Folder) cd DOS FLASH then wait it after it finish. NOTE: Make sure you plugged in your AC adapter.
It is not completely clear if you mean large PC games or if you mean small PC games.
By small PC games I mean games similar to the games that come with Windows and that appear in the 'All Programs -> Games' folder. Such as 'Free Cell', 'Hearts' or 'Solitaire'.
By large games I mean games like 'World of Warcraft' or 'Mortal Combat'.
Also, do you want to install the games on your Flashdrive or store them there?
If you want to store a large game on your flash drive. Place the CD/DVD with the game on it in your CD/DVD drive and insert your Flashdrive in a USB port.
Open 'WIndows Explorer' or 'My Computer'. Locate the CD/DVD drive that you inserted the game disk in (most likely your D: drive).
In the 'Edit' menu select 'Select All' and then in the 'Edit' menu select 'Copy'.
Then locate the Flashdrive in 'WIndows Explorer' or 'My Computer'. And in the 'Edit' menu select 'Paste'.
While this will copy the files from your game's CD/DVD disk to your Flashdrive you may or may not be able to install the game from your Flashdrive.
You can use this same procedure to copy small games to your Flashdrive from your Hard Drive. You will need to know where on your hard drive they are located. And they may or may not run from your Flashdrive.
Also you may be able to install and run games from your Flashdrive, When you run the Setup program from you game disk you will usually be given the option to select a alternative location to install the game. Select your Flashdrive at that point and it may install correctly to your Flashdrive. If it does you should be careful to always use the same USB port or the game won't run.
either download it from the hp website...or copy it to a usb flashdrive somehow...or use an external cd drive or buy an internal cd drive (for about $20)
first do a system back-up, (safe all the content of your disk plus installed programs an configuration using either the included windows back-up wizward(if you still use Win2000) or another freeware program, then copy the resulting file onto your flashdrive(make sure it has sufficient space).Done.
The solution to this is associated with the power supplied by your laptop to the drive. It seems the passport drive needs about 1000mA of current which will be supplied by two USB ports on a laptop. It should be fine with a desktop USB port though is what I was told.
Most flashdrives (aka pen drives or usb sticks) do not require installation. They are a storage device that you add information to. If you could post your OS (either XP, Vista, Linux or Mac OS X) we can go through the process of adding and reading information from the drive.
windows 2000 should recognize the flash drive immediately after it is inserted. The flash drive should install itself. Besides, there are only drivers available on the Memorex website for Windows 98se.
Your desktop usb compatibility is not supported your 160GB. The only way to attach you 160GB is to make it secondary partition to your primary drive by opening the CPU and attach it to your IDE cable.
Don't force yourself if you cannot do it by yourself just leave it to the expert. Probable cause to damage your hard drive if it is not installed properly.
