You can download gospel music firstly and then burn the downloaded music to CD. Just follow below steps. There shows the easiest way to do that.
Leawo Music Recorder is an excellent music recording program which allows you to record music freely from gospel music
1. Run Leawo music recorder on your computer and then you will enter the main interface of music recorder. Press on the icon button "Audio Source" on this main interface and preset audio source before recording music. As we need to record music from online music source like YouTube, the option "Record Computer Audio" should be selected.
2. Press on the red button "Start" to make Leawo Music Recorder start to work. Then click and play music source files. Note that the music recording software must work prior to playing music source files. To make the recordings to meet your requirement, the feature "Task Scheduler" can be pulled out from the left bottom corner by clicking on the icon button "Recording Task Scheduler", where the start time and the duration can be set to your preference.
Burn music to a CD through InfraRecorder
InfraRecorder is free software with an open source which is mainly applied to create your own CD with your favorite music. It can be used with no limitation and no effort. This program can be downloaded freely by the users from the available website. You can follow the guidance as below to learn how to put music on a blank CD from YouTube via InfraRecorder.
1. Download and install InfraRecorder on your computer. If your Windows system is running based on 64 bit, the version x64 can be chosen.
2. After the program has been downloaded and installed, launch InfraRecorder by double-click from the desktop or from the Start menu on computer.
download-and-install-InfraRecorder-on-computer-8
3. To burn a music disc, select "Audio Disc" from the options list, then choose the music you want to burn from the directory on your computer.
click-the-button-open-to-select-the-music-you-want-to-burn-9
4. Click the button "Open", then check the music that you would like to burn, once all the music has been selected for burning, click on the button "OK". The burning process will begin via Infrarecorder.
For more details, you can check this article.
How to Put Music on a CD from YouTube
What do you use to download music?
