20 Most Recent Apple iPod shuffle MP3 Player Questions & Answers
3answers
Down load music
Download or rip music onto your computer using iTunes , then hook up your shuffle to the computer using your USB cord and use iTunes to sync music onto the MP3 player.
11/16/2021 3:11:56 AM • Apple iPod... • Answered on Nov 16, 2021
2answers
Ipod download
You should just download a copy of iTunes from apple.com for your operating system and then install it. Then you just plug your shuffle in and follow the instructions.
8/31/2021 6:23:42 AM • Apple iPod... • Answered on Aug 31, 2021
2answers
Mp3 shuffle wont instal.
download itunes from www.apple.com/itunes the connect your ipod to system and transfer music onto it using itunes sync...you'll know the steps yourself once you download and install itunes...
8/31/2021 6:15:28 AM • Apple iPod... • Answered on Aug 31, 2021
4answers
Ipod to pc music play
You can only transfer music from an ipod to a computer if they were purchased through itunes.
If that's the case, right click on your ipod's name under devices. Then click Transfer music.
1/15/2021 2:38:58 AM • Apple iPod... • Answered on Jan 15, 2021
3answers
Downloading music from my computer,deleting music
There are lots of methods. You can resort to online music download website, chrome extension, or music download software. Follow below steps, to know the detailed information. Leawo Music Recorder is a super recording software to help you record various kinds of music from multiple sources like online music like YouTube, computer audio, and built-in input audio. The recorded music files will be saved into an output format of MP3 or WAV. 1. Run Music Recorder on your computer and enter the recording interface. Audio source should set firstly before music recording. In order to record the music from YouTube, we should choose the option "Record Computer Audio". 2. Click the red button "Start" to make Leawo Music Recorder begin to work. Then play the music on YouTube. You should note that the music recorder should work prior to playing YouTube music. If you want to decide the start and duration time of the recorded music, just click the icon button "Task Scheduler" then you can finish this customized setting as per your requirement. After the music has been recorded from YouTube, you can use Leawo iTransfer to move the recorded music from computer to your iPod Leawo iTransfer is a professional transfer program for transferring files between iOS devices, iTunes and computer. Various kinds of files are supported by this software such as music, apps and photos, etc. 1. Run Leawo iTranfer after you have downloaded the music on your computer. Connect your iPod with your computer via USB cable. The library of your iPod will be detected automatically and shown in the left sidebar of the window. 2. Import files to the software from computer in the following four-way: I. Drag and drop the music files into iTransfer directly. II. Click the button "Add" on the upper part which is beside the left sidebar. III. Click the button File > Add > Add File/Add Folder on the top right corner of the window. IV. Right click on the library and select Add File or Add Folder. 3. A pop-up dialog will be shown once you finish adding files and press the "Transfer" button. The name and the quantity of the transferred files will be demonstrated to let you know the transferring percentage. Remember not to disconnect your Apple device to your computer until the transferring is completed. music-recorder-recording-t-ptaos1411zhprwnu0jdtasew-5-0_1.jpg For more details, check: How to Download Music from Your Computer to iPod
4/19/2019 6:15:21 AM • Apple iPod... • Answered on Apr 19, 2019
11answers
APPLE IPOD SHUFFLE UNKNOWN ERROR 1442
I found a way to solve this, you have to google for a program called ipod reset utility or, you can search here:
http://support.apple.com/kb/HT1238
Either way, install, follow the instrucions and you can probably save your ipod (note; I saved my ipod on a mac. Haven't tested transfering songs from my PC an this moment)
8/11/2018 3:52:25 PM • Apple iPod... • Answered on Aug 11, 2018
2answers
How do i download songs
As with all iPods, you must use Apple's iTunes application to sync your music with your iPod Shuffle.
You'll need to install the latest iTunes by downloading it from Apple click here> and then installing it. You install iTunes like any other downloaded program by double-clicking on the resulting icon after iTunes has successfully downloaded.
Follow the on-screen directions to install iTunes.
Once iTunes is installed, start up iTunes and have it search your computer for music for it to manage for you. While that is going on, plug the white USB cable that came with your iPod into your iPod Shuffle and into one of the USB ports on your computer. This will trigger iTunes to recognize your iPod Shuffle and ask you whether you want to set it up with this computer.
Follow the on-screen prompts to sync your iPod Shuffle with your computer.
To charge your iPod Shuffle, just keep it plugged in to your computer using the supplied white USB cable. Keep the cable connected until the battery indicator on the ipod Shuffle shows that the battery is full.
Thanks for using FixYa and Happy New Year!
8/9/2018 2:56:12 PM • Apple iPod... • Answered on Aug 09, 2018
Apple ipod shuffle manual
You may view/download the manual at Apple iPod shuffle MP3 Player User Manuals Guides
11/4/2016 3:05:25 AM • Apple iPod... • Answered on Nov 04, 2016
0answers
How can I download my music to my Ipod shuffle iam not sure how to do it
you connect your ipod to your computer with the charger and open iTunes and then import your music and put it on your ipod.
3/10/2016 6:31:41 PM • Apple iPod... • Answered on Mar 10, 2016
My ipod shuffle wont turn on or charge at all
Chargers and cables can both go bad. Try new ones.
2/2/2015 8:55:11 PM • Apple iPod... • Answered on Feb 02, 2015
3answers
How do you download music?
Hello.
Welcome To Fixya Community.
In Order to Transfer Music to your iPod Shuffle You need to Install iTunes.
iTunes is a free application for Mac and PC. It plays all your digital music and video. It syncs(Transfer) content to your iPod, iPhone, and Apple TV. And you can add to your collection anytime, 24/7
Download:
Apple iTunes Software.
Additional Help:
iPod Shuffle Manual Guide.
Thank You For Using Fixya.
Please let me Know If you need any Further Help.
10/7/2014 4:07:56 AM • Apple iPod... • Answered on Oct 07, 2014
0answers
You insert an optical disc with digital photos from your most recent family vacation and discover that your computer will not read the optical disc. What might be wrong?
What type of computer is it? The question is posted under Apple iPod shuffle MP3 Player. If the disk was given to you from a professional photographer, it may be a copyrighted disk. Where did the photos come from that are on the disk... i.e. brand of camera? The better the problem is described, the better the solution.
6/30/2014 2:59:45 AM • Apple iPod... • Answered on Jun 30, 2014
Deleteing music on ipod shuttle
unless you used the same computer when downloaded music, then you should be able to delete. Otherwise, you need to sync new music. It will erase all of the other music that is in the shuffle. this really sux. i had that problem. Couldn't even keep the same music.
3/26/2014 10:37:33 AM • Apple iPod... • Answered on Mar 26, 2014
Apple iPod shuffle MP3 Player Logo
Popular Tags
529 questions posted
Popular Products
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
iPod Apple
  • iPod Apple
Most Popular Question
play ipod 2004 nissan almera radio cd
  • Audio Players & Recorders
