20 Most Recent Dual Electronics CECT P168 Cellular Phone Questions & Answers
Do another reset. That one did not work.
Dual Electronics... | Answered on Sep 01, 2017
Try a different card.
Half the time the help desk give you wrong info to get you off the phone.
Dual Electronics... | Answered on Apr 28, 2017
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Dual Electronics... | Answered on Oct 26, 2016
Follow the following:
>Call Center at the bottom
>General call settings
>03 Speed dial
>Check that "enable speed dial" is on
Then
>02 Set number
>You will see a list of "empty"
>Touch on the one you want to assign a number
>Edit
>this takes you to your phone book
>Choose a name from your list and save it to your speed dial.
>To call the number from your speed dial list, click on the "Phone dial" icon, and hold the number down. For example, is the number 2 is home, hold 2 down until you see it dial and there you have it.
Hopes this helps
Dual Electronics... | Answered on Oct 25, 2016
i have the cect phone and i inserted my sims card and now its says closed but will not let me call or text anyone. anybody know how or wat the problem is please help! asap write me back helllp hellp
Thanks so much!
Dual Electronics... | Answered on Oct 02, 2016
send it back your phone is messed up
Dual Electronics... | Answered on May 22, 2015
ur digitizer is broken...if u brought it from a store u kan go bak 2 dat store and git it fixed 4 like $10 to $15
Dual Electronics... | Answered on Mar 27, 2015
dear,
this issue directly related with the charging circuitry... the issue can either be with the charger itself or majorly with the charging ic ...
i had faced this problem with the chinese mobile phone but this can be either with the chinese model or can be with the other...so check the both things one by one...hopefully the issue will be resolved..
regards,
dont forget to rate this if issue resolves.....
Dual Electronics... | Answered on Nov 11, 2014
That app is likely only testing the network speed of your iPhone, and if you're using a cellular connection instead of WiFi, the results will depend heavily on which provider you're with and they're coverage in your area.
If you're using the same WiFi on all your devices, the iPhone 5 should not be slower than other iPhones, there are multiple reasons as to why it is getting slower speeds however.
If you're running the tests at the same time, they may interfere with each other so run them one after the other.
If you're already doing that, your router may be prioritising the other devices over your iPhone 5, assuming other devices are using the internet at the same time.
Dual Electronics... | Answered on Jun 06, 2014
You need to have MMS settings on your phone to receive a MMS , your data plan should be on active status for data(Internet) usage.
Dual Electronics... | Answered on Apr 03, 2014
yes it really protect the touch screen from scratches and spotted.. some good quality screen guard have anti dust and radiation quality also.
Dual Electronics... | Answered on Mar 04, 2014
all you need to to is to delete the old APN as access point name and then put in the new one so that you can access it directly on your mobile if you are using the sim mode.
Dual Electronics... | Answered on Feb 19, 2014
Dual Electronics CECT P168 Cellular Phone Logo
1,501 questions posted
Top Dual Cell Phones Experts
kayceaz
Level 1 Expert
Tin Tin
B.Th. Pluijm
B.Th. Pluijm
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Dual Cell Phones
  • Dual Cell Phones
Most Popular Question
screen guard really protects touch
  • Cell Phones
