20 Most Recent iLO (2 GB) MP3 Player Questions & Answers
i think you should format your mp3 player to Fat32!! that is the best solution, NTFS doesn't support both mp3 & mp4 players
iLO (2 GB) MP3... | Answered on Oct 16, 2019
you cant it stays wav duh
iLO (2 GB) MP3... | Answered on Aug 22, 2019
my mp3 player says that it is write protected when i plug it in ,.... so i was directed to change the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control \StorageDevicePolicies value from 1 to 0 .... when it looked it up i saw that inside the control folder the "storagedevicepolicies " is missing... my comp is normal and is not behaving abnormal..... plz help.... thanks in advance..
iLO (2 GB) MP3... | Answered on Jul 01, 2019
OK – after an hour or so of faffing around :knock: , I think that I have found a possible solution tongue.gif . The problem seems to be something to do with Microsoft’s SP2 dead.gif !
Here’s what worked for me (sorry for the Idiot’s Guide approach, but I used to :hotbounce hate it :hotbounce when I used forums and couldn’t understand what the technobabble meant!):
- Start > Run > type ‘regedit’ (without the speachmarks) > Enter
- Single-click on ‘My Computer’ > File > Export > save it to the Desktop (Always best to have a backup!!)
- Go to the following:
My Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDeviceP olicies
*There seems to be some spaces here in 'StorageDevicePolicies' in the text above, there shouldn't be, OK*
- Double click on the string ‘WriteProtect’ and change the ‘Value Data’ box to ‘0’
- Then: File > Export > save somewhere useful as something like ‘StorageDevicePolicies001.reg’
- You also need to do this for the strings in any folders called ‘ControlSet***’ (* = any Digit, i.e. 001, 002) – for example: Everything is the same, just change ‘CurrentControlSet’ to ‘ControlSet***’
My Computer\HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\StorageDevicePolic ies
- Save these to the same place as before as ‘StorageDevicePolicies00*’
The saves are in case it reverts at a later date, just double click (saying ‘yes’ to importing these to the registry) on all of the files and it will all work again!
Thanks to Fatbird
iLO (2 GB) MP3... | Answered on Aug 22, 2017
torage device policies is missing in HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
iLO (2 GB) MP3... | Answered on Jun 24, 2016
If you are running windows XP.
Right-click on the Start button. Click properties. While in the Start Menu tab click on Customize... button. Under Start Menu items, scroll to the bottom of the list and click the Display on the All Programs and Start Menu under System Administration Tools.
Now, click ok to finish these two windows you have open.
Click Start,
Click Administrative Tools,
Click Computer Management.
Now on the left side there will be System Tools, Storage, Services and Applications. We want to use Disk Management to see what drive letter is assigned to your mp3 player.
If you see a drive that does not have a letter assigned to it. Right click on the drive and pick Change Drive Letter and Paths...
Assign it any letter that you like (that isn't already used by another drive on this list,) and you should be able to view your files to add or remove just like another drive.
Most common reasons for this happening are... You are connected to a network that assigns drive letters to remote drives, or you have usb devices (like card readers) on your computer that have been assigned the letter that your mp3 player wants to call itself.
Please let me know if this helped you fix your problem.
iLO (2 GB) MP3... | Answered on Oct 14, 2015
Get the correct driver/version of the software from Craig's website
iLO (2 GB) MP3... | Answered on Dec 24, 2014
Hi Ali
Sounds like the battery itself may be bad. What type of battery does it contain. NiCad, LiOn
A replacement battery may be available.
iLO (2 GB) MP3... | Answered on Nov 27, 2014
As you said that there is no switch to lock and unlock usb stick so if this is the case than download the file below
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
This will solve the write protect error definitely
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
iLO (2 GB) MP3... | Answered on Jun 15, 2014
1,573 questions posted
Popular Products
iLO MP3 Player
iLO MP3 Player
-27 Questions
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • iLO Audio Players & Recorders
Most Popular Question
remove write protect usb flash drive
  • Audio Players & Recorders
