Car Audio & Video Logo
Posted on Jan 28, 2010
Can't find Jensen UV10 e-brake bypass code. - Jensen Car Audio & Video
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Aug 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
7284
Points
20
Ok what you gotta do is connect the pink e-brake wire with the black wire that is already connected to the radio as the grounding.
UV10 Works 100%!!!!
Greetings from Montenegro
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 30, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7116
Points
10
If you ground the pink wire on the wiring harness, it will bypass the emergency brake.
Anonymous
Level 1:
New Friend:
  • Posted on Jan 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7116
Points
6
Not sure if this will do it, but try this:
w/ the remote hit setup, 5,4,3,2,1,0 this will open another screen press tool icon press break override and switch setting to on(or off, which ever position it isn't currently in.)
hope this help, this is the formula for UV8/9
Anonymous
Level 1:
New Friend:
  • Posted on Feb 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7116
Points
5
Ok so i have not found a fix to this just yet but i do have a work around for now just put a dvd in then on the remote hit setup and type in 5,4,3,2,1,0 and the screen will go from blue to showing your dvd. hope this can hold you over untill i find a code ect...
Anonymous
Level 1:
New Friend:
  • Posted on May 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7116
Points
Jensen uv10 bypass. Hook pink brake wire to ground from radio. just did it and it works fine, video plays all the time now.
Anonymous
Level 1:
New Friend:
  • Posted on Feb 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7116
Points
Hook the e brake bypass to the ground wire, and it will show any time you put in a dvd
4 Related Answers
Anonymous
  • Posted on Dec 10, 2010
SOURCE: How do u bypass the Parkin brake on a Jensen uv10
hook brake wire on radio ground
Anonymous
  • Posted on Jan 01, 2009
SOURCE: Jensen uv8035 brake bypass code
just wire the pink wire to any ground-point of your car...
fkuk
fkuk
  • 311 Answers
  • Posted on May 14, 2010
SOURCE: how can i bypass the brake deal so i can watch dvd
some radios are stupid and look only for a voltage on the pin and says yep the brake is on
some radios are clever and look for voltage on the brake pin and also the virecles speed ect
so i recomend that you first connect the brake pin on the radio to ground and test the radio
if it doesnt work then conenct 12V to the pin and see if it works
i recomend that you get someone in the passengers seat and go out for a quick drive to make sure
my radio is the clever one and it knows when the car is moving or not
Anonymous
  • Posted on Oct 26, 2010
SOURCE: bypass code that works for playing video .
ground the yellow wire and then it will always play regardless of the gear its in
Screen is black but touch still wrks on jensen UV10
i really dont think you have the bypass connected right cause your still being blocked on your screen... re check your wiring maybe something connected wrong or bypass is defective...
[email protected]
My remote wont work on my jensen uv10 and i want to bypass the parking brake. Can you tell my how to do it without remote. Thanks
You don't need the remote to bypass the ebrake withe remote use a tago switch to bypass the ebrake hook it up to the pink wire on back of the deck.
4helpful
2answers
What is the parking/ emergency brake code to bypass the jensen uv10 dvd player
uv10 radio dvd player all you have to do find the wire on the back uv10 radio and ground it..( parking brake wire)
5helpful
2helpful
2answers
How can i bypass the brake deal so i can watch dvd while driving? jensen uv10...
2answers
Bypass code that works for playing video .
How do i get a code for the uv10
If you are talking about the code so you can watch movies while you are driving there is no need. The pink wire that comes out of the back of the stereo that say brake needs to be grounded to a regular ground.
5helpful
3answers
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Top Jensen Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
