20 Most Recent Jensen Iso-Max Stereo Line Output Isolator 1 to 1 Ratio Car Audio Amplifier Questions & Answers
Common fault but as others have suggested, check aerial plug. It does fall out, speed humps vibration,cause it to come out of it's socket.If not this, try a seperate aerial such as a piece of wire or a small screw driver blade in the hole. Press search and see if radio finds a station and locks on.If it does then you know you have an aerial problem and your radio unit is ok. Sadly, if no luck and no result then the only answer is to relpace the unit as it is not servicable.These can be found at some car breakers but take your car and make sure that you buy a tried and tested unit with its pin No. Typical costs are £30 with casette and £70 for cd player.
However because there are so many different types of socket and plug arrangments on these units and they all look alike , don't be tempted to part with any cash until you have got the correct one that fits your car and it works. If does and you have its pin, it will have to be entered to make it work and you have made a written note of it in your Ford hand book , then pay the man. Good luck From been there and have the tee shirt. J.R. Note. Halfords do a fitted alternative replacement for around £150 if no luck and you are prepared to spend that kund of money.
Jensen Iso-Max... | Answered on Mar 23, 2009
YOU HAVE TO GO INTO THE MENU SETTING
Jensen Car Audio... | Answered on Sep 12, 2019
It depends upon whether the sub is powered or passive and impedances match.
Jensen Car Audio... | Answered on Sep 07, 2019
Ribbon from player to screen not properly connected or broken due to unfolding and folding.
Jensen Car Audio... | Answered on Jul 17, 2019
it is not difficult.... why uploading these questions...
Jensen Car Audio... | Answered on May 22, 2019
i searched and found the diagram for you hope it helps.
Jensen Car Audio... | Answered on May 07, 2019
Car Audio & Video Logo
7 questions posted
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Car Audio & Video
Most Popular Question
loss reception in 2002 ford focus
  • Car Audio & Video
