20 Most Recent Jensen VM9510 Car DVD Player Questions & Answers
2answers
Region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
5/19/2020 7:05:54 AM • Jensen VM9510... • Answered on May 19, 2020
FORGOT PASSCODE ON JENSEN VM9022HDN
I just fixed mine. Instead of the 0123456, you do it in reverse. So 6543210
2/13/2019 7:08:35 AM • Jensen VM9510... • Answered on Feb 13, 2019
Jensen vm9412
the code is 0123456
2/16/2018 6:07:44 AM • Jensen VM9510... • Answered on Feb 16, 2018
4answers
Bypass code for dual xdvdn9131?
dont need a code just get a toggle switch and hook that to the yellow/blue wire and with the other side ground to the small lil screw where you will see a small lil short wire and then all u have to do is fallow the screen with the e brake but just flip the switch 3 times with the whole one sec then off for 3 sec then on
9/13/2017 8:51:21 AM • Jensen VM9510... • Answered on Sep 13, 2017
Phase linear UV 10 Multimedia player.
CAN I ADD AS AUX OR SOME WAY TO MY EXISTING STEREO? HOW?
12/9/2015 8:59:16 AM • Jensen VM9510... • Answered on Dec 09, 2015
4answers
Jensen vm9510ts
my jensen vm9510 ts turns on and you can listen the radio dvd's cd's but the screen do not come out even if you reset it and press the open button, so you can't seen anything is already coded to play dvd's with out eh parking brake. If any one can help me please.
8/27/2015 8:59:53 PM • Jensen VM9510... • Answered on Aug 27, 2015
2answers
I am looking for a Boss BV9970 wiring harness.
You don't need a wiring harness for the radio unless you lost the one that came in the box with the radio. You can find a wiring harness for your car here.Fit My CarThat will list all the things that are compatible with your car, including aftermarket wiring harness to connect a stereo.
5/3/2015 8:26:22 PM • Jensen VM9510... • Answered on May 03, 2015
2answers
Parking brake bypass
apply 12v positive to the wire to bypass the parking brake
9/26/2014 6:37:58 AM • Jensen VM9510... • Answered on Sep 26, 2014
2answers
Se olle pero no se ve el video aunque este el cable rosa conectad
se escucha pero nose vee sepone asul la pantalla
9/23/2014 2:42:58 PM • Jensen VM9510... • Answered on Sep 23, 2014
0answers
Awm975 only plays in black and white
Stop getting that brand or make and get one from a different manufacturer
5/9/2014 1:13:51 PM • Jensen VM9510... • Answered on May 09, 2014
How to hook up a reverse switch for a a stereo system?
The simplest way is to run a wire from the reversing light bulb
4/20/2014 5:52:12 PM • Jensen VM9510... • Answered on Apr 20, 2014
Why won't the Navsure 420i store any station
Its main system control memory IC is faulty. Replace it. Gopakumar Gopalan Google
4/16/2014 5:50:49 PM • Jensen VM9510... • Answered on Apr 16, 2014
Jensen VM9510 Car DVD Player Logo
596 questions posted
Top Jensen Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Car Audio & Video
Most Popular Question
awm975 only plays in black white
  • Car Audio & Video
