20 Most Recent Jensen CD-2010X CD Player Questions & Answers
Check your dash bulbs and fuses.
Jensen CD-2010X... | Answered on Jul 14, 2014
The wiring harnesses for this system has been discontinued due to the age of the product release.
The harness may still be available from the Jensen repair facility:
PRO Tech Electronics
90 Mosswood Blvd.
Suite 500
Youngsville, NC 27596
Their telephone number is 919-562-5445, and they can also be reached by fax at 919-562-4902.
Your best bet is to call Jensen directly and order a replacement.
1. New to the Support Site :
Click here to go to the Support Account Creation Page so you can submit a support request and we can respond.
2 . Returning Customer:
Click Here to Go to the Ask A Question Page so you can submit a support request and we can respond. Note: You may have to login if you haven't already.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jensen CD-2010X... | Answered on Apr 15, 2011
Hi nicholelawre,
The fault came from a dirty tack switch(channel button) in the front panel. You may spray some contact cleaner to clean the contact from dirt that causing the resistance and automatically detect by the system which caused of the symptom. If the steps didn't help, the switch need to replaced with new one.
Hope I helped you.
Thanks for using Fixya.
Jensen CD-2010X... | Answered on Apr 09, 2011
you may have a bad volume down switch.
Jensen CD-2010X... | Answered on Mar 01, 2011
You might not be able to fix this problem. But first, here is a sugestion you can try. Remove the faceplate and inspect the metal contacts on both the deck and the faceplate. Each contact operates a different function of the radio such as providing power to illuminate the faceplate. Make sure no contacts have been broken, pushed in, or have corrosion. Once they all look good, replace the faceplate and see if it lights up. If not, its an internal problem with the unit and should be professionally repaired or replaced.
Jensen CD-2010X... | Answered on Jun 21, 2010
that's for the auxillary.. like cd changer...
Jensen CD-2010X... | Answered on Jun 07, 2010
it is called a sleeve try car toys or quality auto sound
Jensen CD-2010X... | Answered on Feb 23, 2010
Your reader could be damaged. The reader is the small infared light that is under the CD in the unit. I bet my bottom dollar, it takes about 5 secs before error appears. You may have to go to your local radio expert and ask them if they can repair your reader. he will tell you if it is economically viable to do this, or better to replace whole unit. If still under warranty, take it back.
Jensen CD-2010X... | Answered on Mar 17, 2009
after pressing the display button, and the clock starts to flash, press the up-down (volume arrows) for the hour and the side arrows for the minutes.
Jensen CD-2010X... | Answered on Mar 12, 2009
Welcome to JENSEN go to this site and sign in. Tell them your problem and they will send you a site to down load the manual. I just recieved one for my Jensen CD2010X
Jensen CD-2010X... | Answered on Oct 28, 2008
need cables that go from receiver to car wires. can you please help
Jensen CD-2010X... | Answered on Aug 07, 2008
try to rewire it maybe it was wired wrong
Jensen CD-2010X... | Answered on May 28, 2008
hi penguinxy.
try get a original cds if it works fine.the next time you burn cd try burn at 8x or low may be your cd lens is not detecting cds burnt at high speed.hope this helps..
Jensen CD-2010X... | Answered on May 11, 2008
What is your power wired into? Are your head lights dim also? You may have a battery issue?
Jensen CD-2010X... | Answered on Apr 10, 2008
Jensen CD-2010X CD Player Logo
Popular Tags
21 questions posted
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Car Audio & Video
Most Popular Question
face plate not light up anymore
  • Car Audio & Video
