20 Most Recent Jensen A300HLX Car Audio Amplifier Questions & Answers
Yes you can. That should be no problem.
Jensen A300HLX... | Answered on Oct 05, 2011
It is mostly a ground hum. You can fix this problem by buying a ground loop isolator. Another problem you may be having is the preamps on your stereo unit are bad.
http://www.radioshack.com/product/index.jsp?productId=2062214
Jensen A300HLX... | Answered on Jun 24, 2011
let me know what and how you connected to the amplifier?
Jensen A300HLX... | Answered on Feb 16, 2011
I can solve this one fix it your self since no one here is any help to u
Jensen A300HLX... | Answered on Mar 28, 2010
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS AND POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jensen A300HLX... | Answered on Jan 06, 2010
usually because of bad ground try using a wire brush to remove any corrosion, paint, and or rust under ground wire
Jensen A300HLX... | Answered on Jul 08, 2009
DISCONNECT THE GROUND WIRE. SAND ALL THE PAINT FROM THAT AREA AND REGROUND IT. WHAT I WOULD RECOMMEND IS DRILLING A HOLE THROUGH THAT TRUNK, SAND THE PAINT AWAY FROM WHERE THE GROUND WIRE WILL GO AND BOLT THE GROUND WIRE TO THE TRUNK BOTTOM. THE PAINT WILL CAUSE THE AMP NOT TO GET A SOLID GROUND
Jensen A300HLX... | Answered on Feb 24, 2009
Ill go for a better GROUND , sounds like its not grounded properly and thats why the RED LIGHT . DO A RE CHECK on the installation . hope this helps
Jensen A300HLX... | Answered on Jan 09, 2009
If you followed the instructions correctly, then the amp must be defective. This is sort of simple.
My generic suggestions:
You have the power, the ground, the outputs to the speakers, and then the input.
Make sure that none of the speaker wires are somehow being grounded. Make sure that nothing is shorted that feeds the speakers.
Jerry G.
Jensen A300HLX... | Answered on May 01, 2008
how did you connect your amplifier?
Jensen A300HLX... | Answered on Apr 22, 2008
if you have a 25 Watt amp (per speaker) then go to radio shack and get (2) 50 watt resistors (8 ohms each). attach them like speakers. turn it on half volume. they should get quite warm to the touch.
Jensen A300HLX... | Answered on Jun 10, 2007
schematic & instructions on deck red (+) - power - 2 amp's power inlet power (+) black (-) - ground - 2 amp's power inlet ground (-) deck yellow wire - remote - 2 the remote amp deck outputs 2 the RCA amp inputs amp RCA outputs 2 speakers it is wise that a pro will install the system it will give u less concerns and u will have warranty on the installation this will save u the money u will spend for fixing a bad installation
Jensen A300HLX... | Answered on Feb 06, 2006
Jensen A300HLX Car Audio Amplifier Logo
20 questions posted
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Car Audio & Video
Most Popular Question
a300hlx amp 600 watt jl audio sub
  • Car Audio & Video
