HP LaserJet 5550DN Printer Logo
Posted on Jan 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have replaced the printer cartridge (x3) and I am getting a error code 10.10.00 with every one of them on the printer. I have run through the cold start functions and nothing. Any suggestions?
Milind Shetti
Level 3:
Guru:
  • HP Master 829 Answers
  • Posted on Jan 26, 2010
Milind Shetti
HP Master
Level 3:
Guru:
Answers
829
Questions
0
Helped
381693
Points
2380
10.10.00 SUPPLIES MEMORY ERROR alternates with For help press ? Possible printer control panel error message 10.10.00 SUPPLIES MEMORY ERROR Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 10 = memory is missing
yy
  • 00 = black print cartridge
Action
  1. Turn the printer power off, and then turn the printer power on to clear the message.
  2. If the message persists, click here to access to the HP support Web site at http://www.hp.com/support/lj2300 .
2answers
Error code b504 canon printer
Canon error code B504 is built-in security to avoid fragile resistors in the printhead from overheating and self-destructing. The concern exists because there is no ink flowing to the printhead to keep it cold, which may occur when the cartridge is running fully dry or no ink is flowing. What occurs when you enter a new cartridge is that the printer immediately looks to clean the default printhead, so if it doesn't find any ink present at the print-head, this is when the infamous B504 error is registered.
It typically occurs to printers who print head as printers get overheated and may experience self-destruction. This problem happens when there is no supply of ink to the print head to keep it cold. So it probably happens when the cartridge is fully dry or the ink does not flow into the cartridge.
I Hope you get your points. For more - Canon error code B504
How do I resolve ink system failure 0xc18a0306?
When powered up press the ink button. This should cause the print head to move to the middle the printer and then back. If it parks properly then everything should be fine. However, if it stops against an ink cartridge it's indicating a problem (no ink/ faulty cartridge). So replace it and repeat the process x3 (ie.for the 3 other cartridges). Once complete the printer should be OK. All this should be covered in the HP user manual.
HP Official Site Laptop Computers Desktops Printers Servers Services and...
2answers
Dell error code ofoo 0131d
It is unfortunate that the computer displays an error code as "ofoo 0131d". Request you to use the below link and install My Dell:
http://dell.to/1cn35y5
Then run a diagnostics using My Dell and let me know the test results.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
3helpful
5answers
Error code 1688 check ink coloured-replace cartridge still does not print
you cant refill this cartridge you need to buy new one and replace to old cartridge
2answers
Error Code 1102 on Lexmark P6350 Printer
Hi, it seems that it's a cartridge problem. That's the most probable reason why you're getting that error code. Try this out.
1. Remove cartridges.
2. Unplug printer from power outlet.
3. Then, plug printer back in power outlet after 10-15 seconds.
4. Reinsert cartridges.
If error still appears, redo steps 1, 2 and 3. Then, insert black cartridge first. If error appears, replace black cartridge. If not, insert color cartridge, if error appears, replace color cartridge. Hope this helps.
6helpful
2answers
I just put in a yellow cartridge. Previously the printer was working just fine. Now it is showing an error code: 10.92.00 So I put the old yellow cartridge back in. The same error code now appears? He
Hi ron0911170:
This is your problem.
10.92.YY CARTRIDGES
NOT ENGAGED
alternates with
Open and close
front door.
The cartridges are not engaged,
poor primary transfer bias contacts,
defective high-voltage supply, or
control signal errors.
YY Description:
00 - Black print cartridge
01 - Cyan print cartridge
02 - Magenta print cartridge
03 - Yellow print cartridge
1. Open and close the front door to fully
engage the cartridges.
2. Reseat the print cartridges.
3. Check the printer primary transfer bias
contacts to the transfer unit. Clean if
dirty. If the contracts cannot be
cleaned or they are damaged, replace
the transfer unit.
4. Replace the high-voltage power supply
PCB.
5. Replace the DC controller PCB.
Hope this helps
1helpful
4answers
What is Error Code 1102
If you get errors after refilling and then you clear the error! And you still get errors occuring then this is a problem with the cartridge.
1)The cartridges printhead may have burned out if it was run dry. (new cartridge is required)
2) No ink is coming out of the port hole! Try dabbing the bottom of the cartridge on tissue. Ink should appear if not then use tissue with Isopropyl alcohol and blot lightly until ink apppears.
3) If not ink appears then you may have an air bubble blocking the flow of the ink. wrap cartridge tightly in plastic wrap holing in an up right position whip downwards this will force air to the top of the cartridge and open the port on the bottom. Remove wrap and try it out.
4) If the cartridge sat empty for a period of time before refilling you are wasting your time. The ink is probably sitting at the top of the cartridge and can not migrate to the bottom, in this case it may have burned out.
In refilling of Lexmark cartridges:
Refill often and do not allow them to run dry. Running them while there is not ink in the cartridge burns the print head out and the cartridge will not work and you will get an error.
By refilling often the cartridge stays in good condition, you do not run out of ink during a print job, and the cartridge will have a prolonged life span.
k24674
Grand Canyon Tech
Grand Canyon Tech
