20 Most Recent
Canon Pixma MX452 Questions & Answers
How to fix Canon MX452 when it shows Error 0x000003eb?
Error 0X000003EB is a very disturbing error. If you are viewing the same crash check this blog and Just understand the steps which are written on the blog to retaliate the Error 0x000003eb. We give online direction for Any problem in Printer Errors.
Error 0X000003EB is a printer error. If you are attempting to connect a printer, but cannot do so because of the error code 0x000003eb, then you are in the fittest place because we are going to explain today how to resolve this problem. The error report does not give you much message because it only means that the printer cannot be connected and provides you the error code 0x000003eb.
Right Steps to Resolve Error 0X000003EB:-
1. Checkout sure Windows Installer Service is running not.
2. Do Perform Clean Boot.
3. Check Registry Fix.
Error 0X000003EB is usually caused by wrongly configured system settings or different entries in the Windows registry. This error can be fixed with this Mentioned Blog.
Why does my canon PIXMA 452 say pc not connected when I hit the start scan button
Hi, several things i would be asking
Do you get an error code?
Is the error on the PC or Printer?
Can you print?
How is the Printer connected USB or Wireless
the first is the error code will determine where the fault lies.. if in the 5000 range.. its a hardware problem and would need to be repaired by a service center or repairer.
if you get the printer error.. check the cable or wireless connections
if the PC error it could relate to software you are using to scan too, even if you acquire the correct twain driver (select source).. some are not compatible.. try the scan function in your Canon Utilities IJ Scan Utility. Scan it there first and save it as a PDF or image file.
if you can print its not a connection problem if you cannot print try another USB/printer cable Or make sure your device is setup for wireless run the installation software again and complete the wireless procedures in setup. I hope this helps.. or post me the error code and i can give you a definite answer.. Cheers!
What is support code 5040
this is a non repairable code. all you can do is try to clear it by removing power from the wall wait almost a minute and plug back in. if if clears fine but if not it needs service.
Printer error 5012
Hello, this is from the service manual
22 times Flatbed motor error
[5012] (1) Flatbed motor flexible cable connection:
-> Re-connect the cable.
(2) If the error still occurs:
-> Replace the part(s) listed on the right (under
"Parts to be replaced if the listed solutions are
not effective").
-Scanner unit with the flatbed motor cable
Prints with a double vision quality
Use the print alignment feature and follow the directions precisely. If the print heads won't align properly to get a clear image in the self-tests... get a new printer. It isn't worth repairing. If your cartridges are fairly full, buy another Canon that uses the same cartridges and install them on the new machine... keeping the unopened ones for spares. This will help defray the cost a little.
Just downloaded Windows 10 and able to print but not scan. Getting 3,202,19 error code
Hello, my name is Steve. And you are half-way there.
Next you need to go to Canon's website and in Driver and Support, get the latest drivers for your Canon. printer.
Your present software does not have these new updates. this is why you are getting this error code for your scanning support. It is not yet compatible with your new platform.
Hope this helps, best regards,Steve
