20 Most Recent Dell Inspiron 8600 Notebook Questions & Answers
2answers
Dell error code ofoo 0131d
Hi, It is unfortunate that the computer displays an error code as "ofoo 0131d". Request you to use the below link and install My Dell: http://dell.to/1cn35y5 Then run a diagnostics using My Dell and let me know the test results. Thanks and Regards. Kiran Kumar. #iworkfordell.
8/2/2019 12:04:19 PM • Dell Inspiron... • Answered on Aug 02, 2019
AM UNABLE TO ACCESS YAHOO AND FACEBOOK
It is possible the cookies have been disabled in your browser. You need to find where your internet settings are in the control panel and make sure cookies are on. I had the same problem and activating cookies in the internet options fixed it.
1/4/2015 9:41:10 AM • Dell Inspiron... • Answered on Jan 04, 2015
2answers
Unmountable boot volumn error with lines on screen
this may help. just watch the video and folow the directions. good luck.
11/22/2014 7:16:37 PM • Dell Inspiron... • Answered on Nov 22, 2014
Dell Inspiron1410 running 50% CPU usage with no other processes running in background. This after a nice repair install of Windows XP professional. High fan noise and heating up! Thanks
Hello Saman Tarik, Task manager may say there are no other processes running but if you look in the next tab, "Services" you will find there are many things running. The processor will run at a lower percentage when it is not busy. As for running hot, I would suggest that the heat sink fins need cleaning out, I was surprised at how much fluff had accumulated in them, preventing a good air flow. I have upgraded my processor from 1.5Ghz to 2.5Ghz which runs hotter so I bought a ZALMAN ZM-NC1500 USB and the hottest my CPU has reached is 41 degrees when both cores are running at 100%. I hope the above information is of use to you. Kind regards, Ron.
6/16/2014 10:40:32 PM • Dell Inspiron... • Answered on Jun 16, 2014
I cant find the songs on my CD
Go to your computer. Then click on dvd/cd drive. Then you can rip the music to ur computer.
5/12/2014 11:47:15 PM • Dell Inspiron... • Answered on May 12, 2014
Where is the wireless switch
Function (Fn) + F2 turns on all wireless devices.
3/13/2014 9:11:59 PM • Dell Inspiron... • Answered on Mar 13, 2014
Reset bios password
in desktop computer this can be done by shorting cmos reset dip switch or removing cmos battery momentarily for a couple of seconds or minute at least. If you are working on a laptop computer the location of the dip switch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
12/3/2013 12:01:10 PM • Dell Inspiron... • Answered on Dec 03, 2013
DELL INSPIRON 1410 idle process takes high processor usage and heats up my pc
If running Windows OS - there could be several background processes running causing this higher CPU usage. Hitting 'CTRL/ALT/DEL' will bring up the task manager (Win98/WinXP) or a Menu which has task manager (WinVista/Win7/Win8), you can then see what background programs are running.
11/21/2013 3:14:05 AM • Dell Inspiron... • Answered on Nov 21, 2013
How install Loacal Area Connection
is it jock??? :Dwhen you connect cable, operating system automatically install it... :)
10/22/2013 1:28:47 PM • Dell Inspiron... • Answered on Oct 22, 2013
Need to reset both sign in and password for sameone on entire computer
you done it with help of "Hiren's All Boot CD" search on google and download it's iso and make CD...
10/22/2013 1:27:01 PM • Dell Inspiron... • Answered on Oct 22, 2013
Slow computer shutdown
before shut down close 1 by 1 all opened programs, then refresh 2-3 time on desktop... or... format your c: drive and re install windows...
10/22/2013 1:25:30 PM • Dell Inspiron... • Answered on Oct 22, 2013
My cd rom drive does not recognize media
First check CD (bad, scratch) Change it... if not OK thenthen Check Software (like media player, VLC player) re-install it if not OK then...Then check Cable of cd rom (loos connection) in not OK thenbring any friend's or neighbor's CD ROM for few minutes and replace... if other CDROM working ok then problem in your CD ROMopen cd rom and Check Lance (head) of CD rom... mostly lance not working in these cases.
10/22/2013 1:19:25 PM • Dell Inspiron... • Answered on Oct 22, 2013
Web site of
They may have server problems. Go to www.comodo.com for free anti-virus and firewall. Click on "download free Internet Security" button.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
10/22/2013 12:59:08 PM • Dell Inspiron... • Answered on Oct 22, 2013
#**84GB8545T-595B the system Primary HDD is
sorry the only option left will be to fomat the disk coz without the correct password its all vain. sorry
9/23/2013 1:37:03 PM • Dell Inspiron... • Answered on Sep 23, 2013
4answers
Quick heal
Ok this is one of my two options since I cannot install the software to give a exact no fail answer for ya:
1) Open My Computer
2) Go to Program Files
3) Look for something called Quick Heal
4) Open that folder and then look for one of the following files:
[Note: * 's are Widcards: Meaning anything after or in place of that is fine.]
unins*.exe, uninst.exe or anything called Uninstall or like it.
If you see one run it as it will most likely work and remove it for you.
Also in some rare cases there is a Setup.exe that has the capability of removing the software as well.
My second option would be to if you can find the Quick Heal folder is to click the folder once to highlight it, Hold Shift and press Delete to permenantly delete it and then go about something that works but I warn you if you do any mistakes can cause issues:
1) Go to Start > Run
2) Then type cmd and hit enter.
3) Once you see the run Dialog type: msconfig
4) Press Enter
5) Go to the services tab and uncheck any box that in the manufacturer says Quick Heal in any means or is in the Startup Item Part.
6) Go to the Services tab and before you do anything check the "Hide all Microsoft services"
7) Look under Service and Manufacturer for things labeled Quick Heal and uncheck them
8) Click Apply and then Ok and then then the reboot option.
This process should manually remove Quick Heal but I suggest you only do this for this program.
I sincerely hope this helps.
7/29/2013 7:11:01 AM • Dell Inspiron... • Answered on Jul 29, 2013
Force shut down doesn't work
pullout battery and powercord
2/24/2013 12:00:50 PM • Dell Inspiron... • Answered on Feb 24, 2013
Dell Inspiron 8600 Notebook Logo
229 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
84gb8545t 595b system primary hdd
  • Computers & Internet
