Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV Logo
Posted on Jan 18, 2010
My 52inch xbr4 tv is 2 years old. Intermitently over past 2 months, when I first turned it on, I get thin vertical lines and double imaging especially over left half of screen. After a few minutes it would clear up. Now problem last longer, especially yesterday lasted 4 hours. I thought it was cable but repair man came today, disconnected box and problem remained on screen, even when drop down input button is presed?
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Mar 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
11583
Points
12
I have the same issue. Bought the TV 1/08 and it started showing those exact symptoms about 3-4 months ago. It generally progresses and gets worse. You can try to fix it as it's some kind of TAB connector issue, or keep calling Sony so that the 52" owners of the XBR4 and 5 series get the extended warranty just like the 46" owners received for the same series. If enough of us keep calling, they'll have to act.
2answers
Double image in samsung lcd tv
IF it is still under warranty, take it in to be replaced.
Only get black & white, double images
bad power circuit may cause such problems.
may be power ic or bad capacitors.....
20helpful
11answers
Sony XBR4 - 46 inch Double Imaging and 1/2 screen dark
We have a SONY XBR4 and we are experiencing the same issues. When you turn on the TV, the right side is dark, then there is shadowing with movements. After about 15 minutes the picture is fine. Sometime shortly after you will get a dark area in the middle of the screen (this doesn't happen all the time). I called SONY, they were not helpful at all. They told me because the TV was not under warranty - it is only a year and a half old, they couldn't do anything for me. We had one of their service people come out to look at it. They basically told us its the panel and it has to be replaced. The cost is $2000. NEVER BUY SONY AGAIN!!! You might as well go and buy a new TV.
I have a thin vertical line about 9"from left side runs top to b
either a bad buffer pcb or display panel, 12 month warranty call panasonic quick
Sony Bravia XBR4 52inch LCD cracked
It can be replaced, but it is probably going to cost you more then the cost of a new TV to do it.
Read the tech tip I wrote on this very subject.
http://www.fixya.com/support/r3831376-when_cracked_lcd_led_or_plasma_tv
9helpful
My Sony KDL-32XBR4 has vertical lines for 5-15 minutes on startup
I have a 46 inch , Sony XBR 4 tv . The past week there has colored vertical lines that appear on the screen for about 10 minutes . Then they go away . What is the problem and solution?
1helpful
Thin vertical line
You are going to find it is a LCD panel problem. I am sure that they will take care of you. But also realize that this could have happen to any brand of LCD panel and you will probably not have any other panel issues once it is fixed.
I feel your pain,
Skyassoc
37helpful
6answers
Vertical line on my 46" toshiba lcd tv
The only logical solution for the problems people are having for the toshiba regza's tv's is to get into a class action law suite..., they contiue to sell tv's with defective parts and refuse to help the customer that spent large cash to find out they last if your lucky 2.5 years, they are junk and anyone with one will soon find out./.......
36helpful
6answers
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
