20 Most Recent Mitsubishi WS-65511 65" Rear Projection Television Questions & Answers
looks like the t-con board failing, or a lose connection to the t-con or screen ribbons off the t-con board to the screen.
tcon-y0wguvybehhtyrwlmlutw4ro-5-0.jpg its fitted to the screen back under the shield will look similar to this.
Mitsubishi... | Answered on Dec 28, 2017
WHY DOES IT KEEP TURNING OFF - Fixya
www.asksbook.com/support/t24227796-keep_turning_off
Apr 24, 2014 - These, like most newer tvs have self-checks that shut the tv off if the fault could .... Mitsubishi WS-65511 65" Rear Projection Television Logo ...
[PDF]871D3547B10 (V21 OG) 52 through end.indd - Mitsubishi
https://www.mitsubishi-tv.com/asset/file/owners_guide/WS-55511.pdf
Projection Television Models ... WS-65511 WS-65611 WS-65711 WS-65712 ... which can be determined by turning the equipment off and on, the user is encouraged ...same stationary images on the screen for more than 15% of your total TV
Mitsubishi... | Answered on Jan 19, 2016
I am a expert on these sets and have fixed hundreds of them.
2,2 is short protection and 97% chance one or both of the pico fuses that protect the convergence circuit are blown (bad).
Model indicated uses a single STK-393-110 convergence IC. The fuses and chip are on the middle circuit board which needs to be removed to repair the set. Total parts cost will be under 25 dollars---I use a seller on EBAY who has the chip and the fuses.
I have start to finish step by step instructions for this repair in this model as I have done it hundreds of times.
Soldering and some skill are involved in getting the board out and replacing the parts.
let me know if I can assist you or if you have questions let me know here.
If you decide to repost this question mark it "attention SD TECH"
SD TECH
Mitsubishi... | Answered on Dec 25, 2014
Yes. Rear-proj.with 3 picture tubes. These, like most newer tvs have self-checks that shut the tv off if the fault could worsen problems for the TV (such as damage picture tubes.) or it's not able to put a picture up.
After it shuts off, you can press menu and input/device together for 5 secs, and it will flash a 2-digit code (such as "23" or "24", etc.)(vertical or horizontal error.) Though you will need to call a repair shop for repair. It's usually better if they are Mits. factory authorized, as they'll likely have more exper. on Mits.
Mitsubishi... | Answered on May 09, 2014
lamb is gone out you need to replace it with a new one
Mitsubishi... | Answered on Apr 26, 2014
Try new battery's in the remote, and check all volume buttons, one may be stuck down.
Mitsubishi... | Answered on Mar 23, 2014
if the problem is intermittent it could be bad solder connections on the convergence output ic's but being a noob I don't think I would recommend trying it yourself, Just getting to those connections can be a challenge.
Mitsubishi... | Answered on Mar 15, 2014
IF power light comes on for a moment and then goes off:
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
Mitsubishi... | Answered on Feb 16, 2014
hi,, have u checked your circuit board......
Mitsubishi... | Answered on Feb 03, 2014
check the fuel pump they are good for that
Mitsubishi... | Answered on Oct 27, 2013
175 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
having 3d effect convergence problem 65
  • Televison & Video
