Refrigerators Logo
Posted on Jan 17, 2010
I recently had to throw away some questionable food that had partially thawed in the freezer cabinet of my kenmoore, model# 253.67882508 fridge with freezer on top. i keep this fridge in my garage and in the winter i keep the garage @ 50f degrees usually but ive had trouble with the limit on the garage heater. we had a cold snap here in indy @ that same time so the garage temp has been cosiderably colder. the fridge was made in sept. of '07. if i adjust the stat colder the evaporator fan, the condensor fan and the compressor all turn on and run until the stat is satisfied and the freezer and fresh food temps are -10f and 38f respectively. the evaporator coil is ice free and the condensor coil is clean. was my garage just too cold?
Anonymous
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Jan 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
40
Questions
0
Helped
7406
Points
56
Probably,there is a garage kit available that willallow it to work at colder temps,listed in owners manule under accessories the thermostat senses refrig compartment temps.soif garage temp is below 40 or so the thermostat just doen't turn the unit on enough or not at all
Maytag refrigerator / freezer compressor fan not running and some items in freezer appear to be thawing
Check to see if the fan mount bent somehow. The fan blade just might be jammed. If not see if the fan is getting power. The unit will not cool properly if the compressor and condenser are not being cooled down by that fan.
Fridge threw breaker yesterday. Breaker reset and refrigerator appeared to be operating normally but today freezer food and ice thawed and refrigerator at 44 instead of 37. Reset with digital control but...
throw it away ,sounds like the motor is shorting out inside ,check the wires first in case a mouse had breakfast but i would say the motor is packing up
I have a Kenmore Elite fridge mfg in 2001, when its running it makes a sound and the light in the freezer goes dim everytime it makes the noise and the food in the freezer seems like its starting to thaw,...
try this. switch off unit,do a full manual defrost,no hot water.clean out all vents/drains.then switch back on making sure all door seals flush with cabinet.poss cause unit is working overtime.......
If the ambient temperature is the same or less than the temperature in the fresh food cabinet of a refrigerator with the freezer on top, will the stat ever call for cool? sub question---where is the...
Yes, and if you turn the thermostat colder and the thermostat is in good condition it will. You model was made with a mechanical thermostat with Freon filled probe. You may need to close the cold air flow to bottom during extreme cold days and redirect the thermostat probe closer to the freezer opening but it should work. My refrigerator worked fine in ten inches of snow last year and temps in the teens. Thanks, Sea Breeze.
Kenmore fridge, 7 yrs old, freezer on top. Water sprays periodically from somewhere at top inside of refrigerator, apparently from downward pointing chute or holes on either side. This seems to be part of...
Removed inside rear and floor panels of freezer (ice machine also) as ably advised by your tech. Found ice damming he suspected underneath floor panel. Thawed overnight with pot of hot water in freezer. could see that small rear drain tube was iced shut; why all water going into fridge below. Avoided floor mess from thawing water flow to evaporation pan on floor by tilting unit forward on blocks and laying several old towels inside freezer door to catch water that would run out. Also placed some in front at base of unit on kitchen floor. Continuing to thaw pipe to unclog, it is iced some way down, again as tech said it might. Will reassemble and be careful with freezer setting, in case it may have been too cold. Also, some food crumbs had found their way behind panel near this drain tube and may have fallen in to block it. Will clean out any remaining.
8helpful
Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
GE fridge and freezer cools when it wants to - freezer on top
hard to say, there is many questions left that need answered...does the compressor run, does the fans run? what more could you tell me.... whirlpoolpartssurplus.com free tech support
1helpful
FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
2answers
Bottom mount freezer not getting cold enough
You have a failed component or components in your automatic defrost system. This is why you have excessive frost inside the freezer along the back wall. The timer could be stuck in run mode. The defrost thermostat (bi-metal) could be defective or the defrost heater could be open or shorted.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
