Sony bvw 75 reject the tape a minute after loading it, then displays error 0A on the front panel.
SOURCE: Betacam Sp Error Code
It sounds like you may have blown your threading belt. Pull the lid off and have a look at the small threading motor at the back left side when viewing from the front. there is a geay assembly associated with it that drives the threading ring. If that belt is off or loose you will get the error 09 message. Good luck
SOURCE: Beatcam SP error message
BVW-75 error 09 is "threading motor time out". Look for something obstructing the travel of the threading ring inside the deck (the ring which pulls the tape around the video head).
Try Another tape to confirm it's the tape or the camera mechanism. Check the obvious like foreign debris stuck in the tape loading bay. Sorry I don't have the error codes on hand!
