20 Most Recent Sony Memory Stick PRO Duo (2GB) for PSP Questions & Answers
2answers
Where can i download free psp games
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Hello sir<br /><br />You Can download PSP games For Free<br />By This Site : http://www.emudesc.net/foros/psp/104056-juegos-psp-lista-de-isos-csos.html</span>
3/25/2019 9:08:05 AM • Sony Memory... • Answered on Mar 25, 2019
Folders shown shortcut
sir my scan disk 8gb memory card has shown short cut 1kb what can i i do sir pls help me
2/22/2013 4:35:52 PM • Sony Memory... • Answered on Feb 22, 2013
Psp memorystick won't read
Click start control panel administrate tools computer management disk management right click on your psp drive select properties click tools you should see click check now click start two boxes Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not do anything while the chkdsk utility is in progress any input may damage this drive i have found the best results ticking in one box the returning after it has finished then ticking the other box it might take some time depending on the size of your disk but be patient hope it helps
10/29/2012 5:06:08 AM • Sony Memory... • Answered on Oct 29, 2012
My memory stick works fine in my psp but my pc does not recognize when I insert it into the pc. :-/ It doesn't show up anywhere...Please give an input.
might be that the reader in pc needs to have an extender as some of those are a bit deeper than on other devices perhaps the model of pc might help with next solution
6/3/2012 8:29:15 PM • Sony Memory... • Answered on Jun 03, 2012
0answers
What's your problem?i cant format my memory card
click start click to open on my computer you should see your Usb drive E:
right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions
make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select openRight click the icon of your Usb Drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. click start click on my computer to open you should see your drive right click then select format another way click start control panel administration tools computer management disk management right right click on your usb drive select format if you need more help with this post a reply hope this helps you
4/7/2012 11:04:20 PM • Sony Memory... • Answered on Apr 07, 2012
3answers
Can you help me!!
I recently had the same exact problem with a Kingston SD card of mine. Unfortunately, this usually means that the flash memory is no good any more. This means the data is totally unreadable on the drive now, and you will need to replace the drive.
The good news is that manufacturers tend to offer very long warranties on flash memory devices. I looked up on the Sony support site, and they offer a warranty of five to ten years, which you would fall into. I would call Sony support and start the replacement process. You won't get the files back, but at least you won't need to replace it.
8/22/2011 7:51:29 PM • Sony Memory... • Answered on Aug 22, 2011
2answers
Memory Stick PRO Duo in PSP
If your psp is not with CFW(It`s not hacked) you can not play games from your memory stick
8/20/2011 7:44:40 AM • Sony Memory... • Answered on Aug 20, 2011
Memory card is wrtie protected
Hello and Welcome to FixYa!
I've answered a similar query here.
Hope that will be helpful.
Concerned, Nooh: Team FixYa!
7/9/2011 5:48:31 AM • Sony Memory... • Answered on Jul 09, 2011
Please solve the probleme "There
clean ur memory memory stick wid a soft cloth. especially d goldish part on it's back.
5/20/2011 7:36:29 AM • Sony Memory... • Answered on May 20, 2011
2answers
I have a Memory Stick Pro Duo 8GB will not open on
Problem for Sony Memory Stick PRO Duo (2GB) for PSP I have a Memory Stick Pro Duo 2GB will not open on pc &also not formated
3/25/2011 4:06:51 AM • Sony Memory... • Answered on Mar 25, 2011
My psp Sony memory stick
you will need to re format this card
3/6/2011 1:35:58 PM • Sony Memory... • Answered on Mar 06, 2011
I have buy a psp 2GB memory stick my psp is show
make sure your psp has CFW. if not, reinstall it. I can't really help you out though because i don't fully understand your question. from what i understand, you think that the psp creates .iso files. it doesn't. it uses .iso and .cso files.
2/2/2011 3:35:23 PM • Sony Memory... • Answered on Feb 02, 2011
Hi. When ever i insert
try with an other stick
1/22/2011 4:50:55 AM • Sony Memory... • Answered on Jan 22, 2011
Hello sorry for my bad
There is a format function in the psp itself...it will work..it is in system settings tab... doesnt bother with the pc to format
12/24/2010 2:27:16 AM • Sony Memory... • Answered on Dec 24, 2010
How to put games on my psp?
So you just got your new PSP and you want to download games but you're not sure what to do or where to go? Well this article will show you how download games to your PSP.
First you will need:
Sony PSP with firmware 1.0 or 1.5
PSP Memory Stick Pro Duo
1. Go to the website and pick the game that you want to download.
2. Download the game to your computer making sure that it will work with the version of firmware that is on your PSP player. Make sure the file ends with PSP
3. Insert the memory Stick into your PSP player
4. Connect the PSP player to your computer via the USB cable
5. Copy the game onto your PSP player making sure to place them under the "PSP", "GAMES" folders on your memory stick. If these folders don't exist on your memory stick you will need to create them.
That's it now you are ready start playing your games.
I am adding a link for free download...
http://www.pspmaniaonline.com/
12/24/2010 2:25:00 AM • Sony Memory... • Answered on Dec 24, 2010
How do I put photos from my comuter onto a 2gb
  1. Insert a Memory Stick into the Memory Stick slot in the left side of the PSP. Depending on how many photos you want it to hold, you may need to get a larger one than the stick that came with your system.
  2. Turn on the PSP.
  3. Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
  4. Scroll to the "Settings" icon on the home menu of your PSP.
  5. Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
  6. If there isn't one already, create a folder called "PSP" on the PSP Memory Stick -- it shows up as "Portable Storage Device" or something similar -- (you can use Windows Explorer on a PC, or Finder on a Mac).
  7. If there isn't one already, create a folder called "PHOTO" inside the "PSP" folder (on newer firmware versions, this folder may also be called "PICTURE").
  8. Drag and drop image files into the "PHOTO" or "PICTURE" folder just as you would save files in another folder on your computer.
  9. Disconnect your PSP by first clicking on "Safely Remove Hardware" on the bottom menu bar of a PC, or by "ejecting" the drive on the Mac (drag the icon into the trash). Then unplug the USB cable and press the circle button to return to the home menu.....
hope this helped..good day..please vote...
12/24/2010 2:24:08 AM • Sony Memory... • Answered on Dec 24, 2010
I mistakley formated my Sandisk
im sorry but you can not do that all data is gone
8/31/2010 2:05:20 PM • Sony Memory... • Answered on Aug 31, 2010
MY memory stick can be seen and read in my pc but
  • Flash Storage:
  • Memory Stick PRO Duo Expansion Slot pspphatmodelnumber.gif pspslimmodelnumber.gif pspbritemodelnumber.gif
All flash storage, including Memory Sticks and internal flash, uses the FAT32 file system. http://us.playstation.com/support/answer/index.htm?a_id=1055
The above shows how to format the Memory Stick PRO Duo in the PSP so the correct file structure will be shown.
Be sure to back up any data on the Memory Stick PRO Duo before doing this as all data will be lost on the Memory Stick PRO Duo device.
8/6/2010 3:45:55 PM • Sony Memory... • Answered on Aug 06, 2010
Sony Memory Stick PRO Duo (2GB) for PSP Logo
82 questions posted
Top Sony Electronics - Others Experts
Sean Wright
Sean Wright
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Electronics - Others
Most Popular Question
memory stick pro duo 8gb will not open
  • Electronics - Others
