20 Most Recent Sony Betacam SP Small Videocassette 30 Minutes Digital Betacam SP Tape Questions & Answers
Contact sony for listing of repair places in or around your zip code.
Sony Betacam SP... | Answered on Sep 19, 2017
Use menu system to access "manual eject". Hold left arrow key and press menu to access menu. Follow from there.
Sony Betacam SP... | Answered on Jun 04, 2013
Yeah, unscrew the 2 top screws. Underneath the lid, there's instructions on how to manually remove the tape. You're also going to have to pull out the tape tray. There's a metal piece holding it down that you can remove by taking out the 2 screws. Then it's a matter of pulling the tray out and turning the tiny gear at the front (not the 2 bigger ones on the side) until it makes the full motion path. Holy ****, that takes a long time. Once you have removed the tape, replace the tray, the holding bar, the 2 screws for that, and the cover.
Sony Betacam SP... | Answered on Sep 09, 2010
Use an hair dryer and warm within the set. If it clears wipe off any dew that has set in . Wipe also the head clear with a good swab. if the fault is recurring then clean the dew switch sensor or replace.
This is found inside the loading compartment , a small square block. about 1.5mm. Helpful. Good day
Sony Betacam SP... | Answered on Jul 14, 2010
The probem as told on another site (sorry, can't remember to give proper credit) is that the pinch roller is not making contact with the capstan. THis is exacly what happened to my 1800 after sitting for a long time with no use. THe solution was to manually excersize the lever going to the solenoid to unstick the mechanism. Then, voila, pinch roller pinches, tape moves, UVW1800 happy again.
Sony Betacam SP... | Answered on Dec 11, 2009
Electronics - Others Logo
38 questions posted
Top Sony Electronics - Others Experts
 Grubhead
Grubhead
Argospete
Argospete
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Electronics - Others
Most Popular Question
error 02 603
  • Electronics - Others
